| Hi ALL! Ive been lurking for almost a year now, and finally need to ask your advice. |
- Posted by stacieann63 (My Page) on Tue, Dec 11, 12 at 20:35
| Here is an old post that addresses kitchen sinks without windows. Some pretty solutions. |
Here is a link that might be useful: Sinks without windows
- Posted by CallMeJane (My Page) on Wed, Dec 12, 12 at 19:40
| Thanks for the link..... :o) |
- Posted by CallMeJane (My Page) on Fri, Dec 14, 12 at 21:49
| How did your meeting with the KD go? You know, many here on GW are really down on cooktops in the island. Apparently, everything is expensive AND it is difficult to provide adequate ventingl |
| Will the rangetop have at least 24" of counterspace on both sides (right/left) and behind it? If so, while it is quite a bit more expensive to vent (both the hood and duct), it should be OK. 24" all around is pretty good safety zone...not ideal workspace-wise, but... Downdrafts are not very good at venting...unless you don't cook much (it's OK if you don't, everyone is different and not everyone likes to cook). If you cook at all, I strongly suggest you vent the rangetop adequately. That means an overhead hood that's at least 6" wider than the rangetop, at least 27" deep, and has stronger cfms (900+ probably). Island venting has to be more robust b/c fumes, smoke, steam, grease, odors, etc. are subject to more and stronger air currents than when against a wall and will spread out and up faster. This means the hood must be wider/deeper/stronger to capture those fumes, smoke, steam, grease, odors, etc. I'm guessing you don't want a true hood b/c of aesthetic reasons. So, are aesthetics more important than function to you? (Again, it's OK for you if they are, we just need to know if your #1 goal is looks rather than function.) You say the sink will be directly behind it. Be very careful when installing the DW - you don't want it to open directly (or even close) behind someone working on the rangetop unless you have at least 48" aisles. So, how do you envision all of this working? It sounds like the Prep, Cooking, and Cleanup Zones are all going to be crammed into the space b/w the prepping/cooking island and the wall run w/the cleanup sink. Is there a prep sink on the island and is the island big enough to accommodate prepping & cooking? You should have at least 36" of workspace for prepping - although 42" is better. So, is your "prep island" something like this: 1.5" overhang + 18" prep sink + 36" of workspace + 36" rangetop (or 30", if that's what you're planning) + 24" of counterspace = 115.5" = 9' 7.5" or, if you're planning on prepping next to the cleanup sink and then bringing your prepped food over to the rangetop, then this would work: 24" of workspace + 36" rangetop (or 30", if that's what you're planning) + 24" of counterspace = 84" = 7' |
