| Hi,
I am trying to help my sister out that is moving into a home and needs all 4 kitchen appliances. Fridge, Oven, Dishwasher and Microwave. I usually research everything and give her a recommendation. She is on a budget, looking to spend no more than $4000 for Stainless Steel. Trying to research appliances will drive you crazy, as it seems no matter which brand there are problems.
| FRIDGES: Basically, the current CR survey results (of 61,000 CR members with newer fridges) show Whilrpool models to be the most reliable. Maytag and kitchenaid are brands used by Whirlpool, not Frigidaire (which is actually an Electrolux subisidiary). Whirlpool also makes some of the refrigerators that Sears sells under its Kenmore brand. The other primary Whirlpool Corp. brands for fridges are Whirlpool, Whirlpool Gold and Amana. Whirlpool bought Maytag/Amana after bad management nearly wrecked them over the last decade. (On the other hand, I've still got my vintage 1998 Maytag 2156. It met the 2001 Energy Star requirements and is barely less efficient than those meeting the current standards.) By the mid-2000s, Maytag and Amana had a deservedly terrible reputation for a while, enough so that it continues to poison the results of the Consumer Reports reliability surveys which go back 6 or seven years. Check out the link below for a recent extensive discussion of these brands in the context of bottom freezer fridges Kitchenaid fridges are gussied up versions of the same thing that Whirlpool sells under its other brand names. Kitchenaid comes back with slightly less reliability basically because almost all of them come with ice-makers and a high proportion of them have through-the-door ice-makers and water dispensers. Ice-makers and water dispensers are the components that can be troublesome and account for a goodly proportion of defect complaints. This is true of all makers. Again, check out the link below because it will lead you to other resources. DISHWASHER: MICROWAVES: EXTENDED WARRANTIES are only as good as the service companies to whom service is outsourced. Several of the national service companies have awful reputations. For a sense of how good or poor warranty service. Check out consumeraffairs.com to see what warranty service can do to a manufacturer's reputation. |
Here is a link that might be useful: Need a new refrigerator, any recommendations on which one?
