Problem with edge of mantel
Posted by mandolynn77 (My Page) on
Fri, Dec 17, 10 at 20:05
I have some woodworking experience making bookshelves and tables. But apparently not enough...
I built a fireplace surround with mdf for the bulk of it and some pine and pvc moulding. But for the mantel itself I used 2 pieces of 7ft long 1x10 pine, screwed one top of the other to make it thicker. It's the better stuff with squared edges and no knots or sap.
The whole thing looked great until I primed it. Then I noticed that you could see the gap between the two pieces of pine used to make the mantel. I didn't want to take the whole thing apart at this point so I tried wood filler on the edges. It looked good, no crack. Then I primed again and waited a couple days. The crack is back.
I used screws (I think 3") and went all the way through both pieces and into the surround legs and center. I did not use glue. So any advice on what I can do at this point? Unscrew it all, use glue between them and screw them back together? Use edge banding? (although I looked into this and it would be expensive because the usual 3/4" wide tape won't be big enough) Separate the two pieces and chunk the top piece altogether? I'm not feeling brave enough to try trial and error again. Thank you.
Amanda
RE: Problem with edge of mantel
Go to a real lumberyard and buy a single piece of pine in the dimensions you want. Or poplar.
Without some heavy duty wood machining tools, there is little chance of you getting any success with that plan.
I don't know how your design goes, but you might be able to cut a strip off one board and glue and nail to three edges of the top board, wide enough to meet the sides of the surround. Then it would look 2in thick. Use glue and clamps.
Thanks guys. I think I will try doing strips around it. If that doesn't work I'll probably just take the top piece off. I'm not completely married to the idea of it being thicker, so if it doesn't work I'd rather not completely tear it up at this point.
Amanda
