a quick cabinet door finish (plywood)
Posted by homebound (My Page) on
Tue, Dec 18, 12 at 13:36
Due to budget constraints of the new owner (frugal mother of friend of mine), I'm looking for a quick and relatively inexpensive method to apply a protective finish coat some new kitchen cabinet doors. They were made out of finish-grade plywood by the DIY seller. They are stained with minwax stain, but appear to be bare otherwise. If I can apply something without removing the doors, all the better. The doors are clean.
Any ideas on products and method of application? I was thinking of brushing on some quick-dry polyurethane, but wondering if wiping on something water-based might be quicker and better.
Thanks much.
RE: a quick cabinet door finish (plywood)
Plenty of waterborne finishes out there. I've had good luck with products of General Finishes. Remember, while they may dry to the touch quickly, curing takes much longer.
There's also a brush on lacquer that dries very quickly as well. It does stink to high heaven, so you'll need good ventilation.
I spray w/b, and yes, it does dry quickly. You might have a hard time getting it to wipe on well.
About the most foolproof finish is a wipe on varnish. You can do three coats a day over three days and be done.
Choosing a finish.
Finishing for first-timers
Wiping varnish
Here is a link that might be useful: Wipe on varnish tutorial
Thanks guys.
