cutting angled slot
Posted by fishlore (My Page) on
Tue, Dec 15, 09 at 12:23
I need to cut a slot in the end of a 3/4" square stock. The slot has to be 3/32" wide and 7/8" long and at a 65 degree angle (25 degrees off plumb).
My 14" Delta table tilts from 0 degrees to 45 degrees clockwise. This works fine by setting the table at 25 degrees and making two cuts 3/32" apart.
My problem: I need to make a mirror image of this slot but my saw table doesn't tilt in the other direction. What do I do?
RE: cutting angled slot
How tall is the piece?
Run it over the saw standing on end using a carriage.
Sounds like the table is on a 14" band saw, not a table saw.
Probably the best alternative is using a hand saw with a guide jig.
How is this even a problem on a handsaw?
Turn the wood 90 degree and use a flat table.
