| I need help big time on how to renovate my staircase.
Stair details The following link shows photos
What I would like to do
Shannon |
| Until I got to the last paragraph, I was inclined to tell you to simply replace the whole staircase. Your plan is so complex that I suspect complete replacement might be cheaper. Are you trying to keep costs down by "renovating" instead? That sort of strategy doesn't work nearly as often as people hope it will. What are you trying to accomplish here? Forget the itemized step-by-step and describe the look you'd prefer over what you've got. It's not a lovely staircase by any means, but the most off-putting thing I see is the dirty / worn carpeting, which is relatively easy to fix. |
| Thank you for taking the time to respond. I am replacing the floors on my first floor. I would like to do any renovations first that would impact on the floor installation. My staircase is not attractive. The handrail is plastic and although it looks fine in the pictures it really does look very cheap. The professional stair and railing people aren’t interested in just replacing the handrail so I need to plan what I could do myself or if it is worthwhile replacing the whole staircase. Since I could be moving within 5 years, I would like any changes to be a reasonable balance of improvement in appearance and cost. I’m very flexible. I would be happy with any improvement. My dogs would ruin hardwood treads so I was planning on just replacing the carpet. It might be nice to put laminate or hardwood on the second floor. That would not be possible without changing the way the banister is installed. I would just like a simple banister similar to the first 4 photos using my existing iron spindles and new iron or simple wooden newel posts and a wooden railing. I don’t know if it is possible to only replace the handrail or if a whole new banister would be more economical. link for pictures of possible changes (see first post for pictures of existing staircase I would like to remove the ½ wall after the winders and add a matching banister. I assume there is a stringer under the dry wall. I would have to embed the spindles in the stringer. I could only do this if I could change the existing handrail because I could never match the existing plastic handrail. I don’t like the placement of the current newel post. I would like to cut the stringers back a bit and install them closer to the first step or change the first step to a curtain step and install the newel posts to the curtain step or in front of the second step. Similar to the last 3 pictures. I am feeling very frustrated trying to find someone to do any or all of this. My floors are on hold until something is decided. I think that I could veneer and cap the stringers myself but fitting a new handrail would probably require a professional stair person. The DIY books have very little info on renovating a closed stringer staircase. I'm really confused about what to do or where to go for help. |
| Have you tried talking with a (more skilled than average) handyman about the project? The problem with modifying, rather than rebuilding from scratch, is that you can't tell exactly what you're dealing with until you begin so it's difficult to quote prices ahead of time. The fact that you're not clear about what you want done -- maybe this, maybe that, etc. -- makes it pretty much impossible. If you asked me to do this job (you wouldn't, though - it's not really my specialty), I would be unable to give you a price until I'd spent a chunk of time working up a clear plan and proposal, which I'd rather not spend time doing unless the potential payoff was worth the time spent. My spider sense tells me that this project could consume a lot of my time for very little reward, and I'd be inclined to steer away from it unless you were paying me by the hour. Paying somebody by the hour and designing as you go carries its own risks, but might be the best way to get it done to your satisfaction. I do think you should get a quote / proposal or two for complete replacement from the stair companies. At least then you'd have something to weigh other options against. |
| I'd demo and start over. Seriously. I'd do wood treads and add a runner down the center for the dogs--with dogs, it will wear out a WHOLE lot faster than the rest of the carpet, and then it's easier to change out. |
