| I have a challenge with dirt particles on large flat production surfaces. Although the industry has specification for an acceptable amount of dirt particles in a finish (usually 1-2). I can not seem to get an acceptable finish. I am using a Catalyzed Lacquer, I have been sanding the entire surface just to repair a few imperfections. I am using a semi gloss sheen. Buffing, to date has been out of the question since it typiclly increase sheen levels. My question is, is there a way to do spot repairs on CL successfully? |
| Do you think that you should look into why your geting the dust / dirt ? What is your spray room like ? Do you clean it often ? Do you have "dust bunnies" hanging from the ceiling of your spray room. What about the type of ventilation ? Is the fan strong enough to suck out the dust in the air ? Are you using an air hose to blow the dust off prior to each coat of finish ? ( Assuming that your cutting between coats) Can you do a "spot" repair ? Do you mean after your all finished and it's no longer in your shop ? I would work on why your getting the dust and try to eliminate it from the start.Then ya don't have to worry about touch ups. |
