Any number of months ago I posted here and Build a House forum on building wooden shutters for my new little house. Would it be feasible for a novice? How?
There was one response from someone else who had done it using biscuits which was certainly beyond me. I've only built a few birdhouses and they all looked like a kindergarten project.
I decided to give it a try anyway and here are the results and what I learned.
First - my method. Louvered was too complicated. Now I think routing would have maybe been easier than I thought then but at the time I thought too complicated so I settled on the board and batten style as the easiest to make.
I used cheap tongue and groove fir flooring from Menards. Only later did I think about the fact that this was an interior grade wood.
It didn't alway fit together that well so though I tried to use the nicest sides face out a few times I had to use sides with flaws. And they didn't fill and sand that well.
Lessons Learned: Either go to a real wood store and get nicer wood and/or use a planer. I was painting them and expressing how upset I was about the final look to a guy who said "why didn't you plane them" DUH! Cuz I'm a novice and it never occurred to me. I built them at a base wood hobby shop and they have planers I just never thought of it. 'smack forehead repeatedly'
The tongue and grove thing actually worked pretty well. I faced a lot of challenges as a novice (a guy left the chop saw at 03 which wasn't noticeable right while cutting individual boards.... and so I had slanting tops and bottoms, etc. etc. etc.) but anyone with half a clue can do this better in half the time it took me.
The tongue and groove thing limits your flexibility on exact widths a little. You have to shave the tongue/groove off the outside boards with a table saw but don't want them to look narrower than the other boards. Since the tongue and groove boards are a little less than 4" your width choices are essentially in multiples of 4. For a little window it would probably look better to use more but narrower boards but then you'd have to use biscuits. I digress.
Tools needed: I used a good mitre saw, table saw, drills, glue, good clamps, deck screws for building, stainless steel for mounting (countersunk) . You could use a circular saw instead of the mitre saw pretty easily but I think you really need access to the table saw for trimming the outside edges of the outside boards. If your more talented than me with your circular saw go for it.
Time: For most people:) You could probably build a set of 2 in an hour and a half. Add another 1/2 hour for filling and sanding (we are talking the fronts only) and another hour for various coats of paint (prime and regular). So at least 3 hours per set plus time at the store.
Cost: I think the fir was roughly 3.70 a 6 foot board, so a little less than 30.00 a set for approximately 2 x 15+" panels, plus you have to add in a tube of filler and a quart of primer and a quart of finish paint. (My windows were 48")
Though I would recommend using better wood. The fir is very soft (how could anyone use this for flooring?) and if you don't have a planer won't look the greatest close up.
In the pictures you can't really see the flaws since its late afternoon and I haven't painted the screws yet. They look ok from the road I think. Sometimes I wonder if a different style would look better or maybe no shutters at all.
I'll have to see if they bug me too much knowing to look for the flaws. In which case I can either buy plastic ones (eck) or maybe use my lessons learned and build a new set - maybe a routered version? But first i want to build a platform bed so that means we're talking a couple of years:)
Trying to give back,
Mary
http://tinypic.com/f1l6bq.jpg
http://tinypic.com/f1l75l.jpg
marys1000Original Author
mindyb
Liberty Township Cabinets & Cabinetry · Holliston Carpenters · Odenton Carpenters · Valley Stream Carpenters · Four Corners Flooring Contractors · Land O' Lakes Flooring Contractors · Lewisville Flooring Contractors · Melbourne Flooring Contractors · New Orleans Flooring Contractors · Whittier Flooring Contractors · Indianapolis Furniture & Accessories · Medford Furniture & Accessories · Greenwood Village Furniture & Accessories · Silver Spring Furniture & Accessories · Carpinteria Furniture & Accessoriesdonald_grow
echoes_or
pattycake_olp_net
allaboutshutters
