| Greetings:
I was at the orange store the other day and was seized with tool lust for a Makita 18v drill with the lithium ion battery. I'm in the market for some cordless tools, and as you know, buying one sort of commits you to the whole line, whether Bosch or DeWalt or Makita or whatever. Sounds like the Lithium Ion technology is a bit better (power/weight ratio) than NiMh and NiCad technologies. This seemed like a really nice drill with lotsa torque and good balance. Anybody have any experience with the other Makita tools in this line? If you were starting out buying a set of cordless tools today, what would you go with? I'll be using them over the next several months as we redo a kitchen. I don't mind paying $$$ if it's a good value for the dollar spent, but I don't want to buy a rolls royce when a honda would do. |
- Posted by mike_kaiser (My Page) on Tue, Oct 31, 06 at 8:17
| You're probably not too far off with the Honda / Rolls Royce analogy. Don't get me wrong the Makita LiON's are very nice drills but probably more expensive than the average DIYer needs. I'm a contractor by trade and it's rare when I use up batteries faster than I can charge them. Maybe I need to be working faster. :-) I'm of the "right tool for the job" mindset -- I don't see much sense lugging around an 18v drill when a 9.6v will do. But I also get to deduct tools on my taxes. The best approach, rather than buying some "set" of tools is to determine exactly what you're needs are and then buy the tools that meet those needs. Maybe that's a set, maybe not. Mike |
| I won't say to buy or not to buy, but I own the Makita 18V LI Impact Driver and it's awesome. I use it for everything, it's light weight and powerful. chris |
| Fine Woodworking has an annual tools issue out now that has reviews of LiOn tools. One useful thing in the review is that it lists all the tools from each manufacturer for that particular line (e.g. drill, circular saw, jigsaw, etc). |
| I have the $200 Makita Li-Ion 18v drill. It is the black and white one that is the "compact" model. It has a 2 speed gearbox rather than three, and uses the 1.5 Ah batteries rather than the 3.0 Ah batteries. The drill is smaller and lighter than my old 12v drill, yet has much more power. I think it was a great buy. Also, if I buy any tools that use the 3.0 Ah 18v batteries, they also work in this drill. If you are using NiCad stuff, you may want a 9.6 and an 18 for different uses. But with this drill, I don't see the need for two. |
- Posted by russmahogany (My Page) on Tue, Feb 27, 07 at 15:23
| I went with Fine Woodworking's advice about 5 years ago and bought a DeWalt cordless drill/driver and a orbital sander, both expensive. They received light use and were well taken care of. Neither one functioned after about two years of light use. That's my expeerience, and I would not consider a DeWalt tool again. |
- Posted by blacknumber1 (My Page) on Sat, Mar 10, 07 at 22:00
| Yellow is way overrated. I will never own a yellow tool. Amazingly some of my cheap power tools have really lasted, my Skil 7.2v drill/driver is still going strong and my Skil 5150 sidewinder still cuts good, both were less than $40 new and both are nearly 12 years old. |
| I went to a clinic at the Home Depot the other night on Power Tool and was told that the Lithium batteries last a lot longer. I was also told that when you unplug the battery from the tool that you should wait a few minutes and let it cool off before plugging it into the charger, otherwise it won't receive a full charge. Gemfire |
- Posted by bobsmyuncle (My Page) on Thu, Oct 25, 07 at 22:02
| If your main purpose is re-doing a kitchen, why wouldn't corded tools work just as well? Just curious why you think cordless is needed for this application. |
| B&D managed to trash their name pretty well by producing cheaper and cheaper tools. They have even made drills without ball bearing, just little wells between plastic to hold the drill & motor shafts and some lube. It sold for about $25. It might be OK for an apartment dweller hanging a few curtain rods, but not much more. Rockwell sold the tool divisions and they had to be renamed. B&D picked it up, renamed it Dewault (after purchasing the radial arm saw company and shutting it down) and have proceeded to do about the same thing as they did to their original name. A motor for a Rockwell/Delta Unisaw runs a couple hundred $$. Baldor made them for many years. I have some Paslode nailers that run on butane, but those are the only cordless tools. |
- Posted by bobsmyuncle (My Page) on Mon, Oct 29, 07 at 21:28
| I've never quite understood the logic of acquiring a brand with a good reputation, then running it into the ground. I guess that's what happens when the bean counters take over from the people who know the market and their products. |
| B&D needed to do something. The cheap line had tainted their name pretty badly. Dewalt was THE manufacturer of radial arms saws for many years, but no longer makes them under B&D. Makita stuff is OK. I have Porter-Cable tools that predate their purchase by Rockwell. Still going strong after over 60 years. |
| I just bought a Ridgid trim router and, though the standard guarantee is for three years, enclosed I found a mail-in card for a lifetime service agreement. This appears to be a standard card used for other sorts of tools as well. Registering for this apparently gives the original purchaser lifetime coverage not only for "defects in materials and workmanship" but also wear items including batteries. It's an impressive offer. I don't currently own any Ridgid rechargeable tools, but this offer looks awfully good. |
