| Help, please! We have Merillat Classic oak cabinets in a natural stain and we want to refinish them. The problem is overwhelming to us. The cabinets are only 8 years old and are in great condition and we can't afford to replace them at this time.
Is it possible to sand and restain the yelowy oak to a more toffee color - not too red and not too dark - just enough to get rid of the yellow, honey look of the cabinets? If so, what process do I use and what product should I use? Thanks for your help. JB |
- Posted by bobsmyuncle (My Page) on Tue, Sep 8, 09 at 8:41
| Just a few warnings: * This is a lot of work. Really a lot of work. * Sanding is possibly the worst way to do this. You will go through a lot of sandpaper and time (see first point), you will likely not get a good result (leave some finish and color that is going to mess up your finishing) and risk sanding through veneers. Use a chemical stripper. * Some of the finishes in use in the last 10-15 years do not strip well. They are tough finishes, but most strippers won't remove them. You would need to find out if this is a finish that you have. |
| bobsmyuncle, Thanks for the heads up about the work involved. If re- staining isn't the option, what about painting the builder grade cabinets? I'm particularly worried about a primer sticking to the laminated end panels. What type of primer should be used and also what is a sanding primer? I would need something that I can brush on rather than spray. I don't have the equipment or the knowhow for that. |
