Tue, Sep 30, 08 at 17:49
| I am building up top coats with gloss varnish in spray cans, so far so good, I had planneed on spraying a satin coat as the last, but it is looking like it will take two coats to get even coverage, from a spray can, because it is easy to miss some spots.
Should I just use an abrasive on the gloss coat and forget about the satin? |
| I would... |
- Posted by bobsmyuncle (My Page) on Tue, Sep 30, 08 at 21:34
| Your choice. It's often a good idea to apply two coats of the final sheen. |
| I will need to do 2 coats of satin because it is getting difficult use abrasive in the grooves and tight spots. Question is though the can recommend 3 coats is there any problem spraying 4-5 coats total? It's a Spar Varnish, I heard too thick of a coating will crack or peel? |
