Wed, Sep 9, 09 at 13:06
| I have done a temporary fix to an old small dining room table. I went out and got 4 2 x 10 pieces of wood. Planed them and attached them to the table. Because of a lack of proper tools and for ease of cleaning, I need to fill in the 3 small gaps that run the length of the table, but I'm not sure what to use. I also had questions as to what I should use to complete the table. The table will be painted black and then I need to put a polyurethane over it...I'm assuming.
Any help or advice would be great! |
- Posted by mike_kaiser (My Page) on Fri, Sep 11, 09 at 11:15
| I'd use an epoxy type wood filler since you're painting, not staining. Read the can of poly carefully, not all can be used over paint. As an aside, how are you attaching these new boards to the existing table top? You need to consider wood movement otherwise the boards can crack or come apart at the seams. |
- Posted by bobsmyuncle (My Page) on Fri, Sep 11, 09 at 13:43
| A second warning on the need or desire to put polyurethane over paint. Enamel paint is essentially varnish with pigment. Why would adding varnish without pigment over the top do anything more for you? You risk it yellowing or peeling off. If you are really looking for a poly-like finish, get some oil-based floor and porch enamel. Poly is not the be-all end-all of wood finishes, despite the way it's marketed. Just avoid low-end latex paint. |
