Sat, Aug 27, 05 at 12:56
| I have some kitchen chairs that are oak stained and finished and there is nothing wrong with them. We moved and the decor is different and I would really like them to be black. I guess from researching that I need to sand before using a primer and painting. The problem is that there are a lot of hard places to get to. These aren't chairs with just straight lines....they have spindles etc. Is there any easier way than sanding...I would somehow have to get in all the little edges etc. If not, I think I might just have to start looking for some black chairs !! |
- Posted by Kitty_in_NC (My Page) on Tue, Aug 30, 05 at 9:56
| You can use a de-glosser - it's the consistence of water. Just wet a rag and wipe them down. This goes by lots of different names - de-glosser, surface conditioner, liquid sandpaper, etc. All paint stores (not DIY) can help you. It's cheap and very easy to use. |
| Thanks Kitty....that sounds easy. I will check it out. In the meantime, I have seen some black chairs at Ikea for $19.99...hmmmm !! |
- Posted by librarymom03 (My Page) on Thu, Sep 15, 05 at 14:54
| Mineral Spirits will take the gloss off the lacquer. I don't know if sanding is really necessary. I would definitly prime them so the paint will coat evenly. |
| Oxalic will help you to clean up the wood and scuff the finish at the same time. You find this in wood (exterior) cleaning solvents and it is also inexpensive as Barkeeper's Friend sold at super markets (where you find cleansers in cans like comet) Use gloves and clean up the chairs well, then prime and paint. Sand only where the finish is loose or too shiny so the new paint might not stick to it. Flood makes a product called Wood Cleaner sold at HD. There is a lot in the gallon container it comes in, but you can clean you deck and all exterior wood with this as well (before painting) |
