Waxy Coating?
Posted by CEFreeman (My Page) on
Fri, Aug 3, 12 at 0:50
I have a large, triptych made of monkey wood.
I admit I have no idea what that is, but it's out of Indonesia.
The carving has a white wax on it.
I was wondering if there were a way to safely remove this wax without ruining the carving underneath?
I appreciate the help!
Thanks,
Christine
RE: Waxy Coating?
I don't know if this is what you have, but there is a treatment called "dusty wax" that tends to work like a glaze. It's a mixture of wax(es), pumice and solvent to make it liquid. I've had to remove some of it and it's not fun.
Using mineral spirits or naphtha on a clean rag will remove a lot of it. Keep the rag on a clean surface or use paper towels. You may need to use a soft brush like an old toothbrush to get into the crevices.
However, it's very difficult to remove it all. Once the MS flashes off, you can buff with a dry cloth.
At this point, I normally pull out a can of dark colored wax and apply it, then buff with a soft horse-hair brush like a shoe brush. That will conceal what's left on a dark wood.
RE: Waxy Coating?
Looks like that's what I'm going to have to do.
I really like this carving, but the white wax actually makes it look pink.
And we just can't have that.
RE: Waxy Coating?
Bobsmyuncle, I just went to look at it and discovered the wax is so thick that some places I can scrape it off with my fingernail. The crevices are end grain and it's way soaked in.
I think I have a huge project ahead of me.
I'm wondering if I could warm it somehow and work in a darker wax. Actually, in this 100degree+ heat, I could just take them outside.
Something to think about.
RE: Waxy Coating?
Not that it makes any difference, but I mis-typed. Dusty wax has rottenstone, not pumice, in it.
Most waxes liquify about 150F.
RE: Waxy Coating?
A heat gun should boil the wax right out of the pores, and perhaps vaporize it. But wipe away what you can; then, finally, scrub with a toothbrush and solvent (mineral spirits, naphtha) and it should be de-waxed.
Casey
RE: Waxy Coating?
Casey, is a heat gun one of those torches?
or can it be as simple as a blow dryer?
RE: Waxy Coating?
Heat guns are the 'big brothers' of hair dryers.
Some models can get over 1,000 F.
