Sat, Jul 22, 06 at 18:10
| I have a loose stair newel and was looking to get an idea about how to best tighten it. I pried off the button at the top hoping to find a bolt that ran through the oak newel that I could tighten but all I found was a short wood screw. I looked in the basement up towards this first floor staircase but no bolt was exposed there either. Without drilling through the newel and bolting it to a riser and then covering it with a dowel, I figure I could cut a window in the lowest painted riser and then get access below the newel to tighten a bolt. Does this sound reasonable and if I wanted to hire a trim carpenter to make this type of stairway repair, approximately how much would you guess it would cost? |
| Newels should be long enough to extend down to the joists and be through bolted to the joists or solid bridging. I use x4 lumber and at last ½ inch fasteners in bored holes. The holes should be undersized enough (1/16 to 1/32 below the fastener) to require driving the bolts. Only unthreaded shank should be in the bearing area. 2 inch washers under the bolt head and the nut are a good idea to avoid crushing the wood. Steel angle iron can be used to fasten bridging between joists if required. An 80 pound load 4 feet from the first fastener produces an almost 500 ft-lb torque. |
- Posted by Andy(amrathke@aol.com) onFri, Feb 4, 11 at 17:44
| Does anyone know how to re-thighten an existing 'round' newel that has come loose. Tailing as a result moves about 1 to 2 to the right+left. I found stabilizer brackets for square base newels but nothing for a round base newel. Any advise would be greatfully appreciated. |
| "Does anyone know how to re-thighten an existing 'round' newel that has come loose. " Every round newel I have ever seen had a square bottom section for attachment. It may be attached to the stair carriage under the last step if it is not correctly attached to the joists below. |
