Can a natural maple finish be darkened?
Posted by lsteen (My Page) on
Mon, Jul 5, 10 at 15:07
Hi Garden Web users:
I have 6 shaker-style dining chairs that have yellowed but are otherwise in good shape. The finish appears to be a natural color. I would like to darken them slightly to hide the yellow. Is there a way to do it without totally stripping the chairs? Could I lightly sand them and follow up with a some type of wood finishing product?
Thank you for your help.
Lynne
RE: Can a natural maple finish be darkened?
The way professional finishers would adjust color like this is with a glaze or toner. A glaze is color that's added between coats of finish. You apply it, manipulate while still wet, let it dry, then top coat with a coating compatible with the under-coat. If these are factory chairs, it's probably some type of lacquer.
A toner is finish with color in it. To get it on evenly, you almost certainly have to spray it. Read: forget Polyshades. These you can make yourself, or you can buy in aerosol cans. Very light application because they go from not quite there to way past right in a flash.
With either method, you can only move the color slightly before it starts looking opaque. So if your understanding of "slightly" is the same as mine, either might work.
You are not likely to find products or knowledgeable advice at the big box or chain paint stores. I'd recommend getting the library or book store and looking up the books by Bob Flexner or Jeff Jewitt for more thorough technique information. Then practice on scrap or the bottom of the seat.
To neutralize yellow, you use a product with some purple in it.
Here is a link that might be useful: http://www.popularwoodworking.com/features/finish6.html
Thank you very much for the advice and link.
