Wed, Jul 30, 08 at 15:06
| I plan to remove the existing old 2" door casing with a wider and pretty one. Some carpenter told me that I do not need to remove the existing baseboard to accommodate the wider door casing. I have quite a few door casings
to replace. Thought if I can just trim the existing basebord (next to the new casing) one inch shorter on the end, then I'll have less work to patch the wall and less damage to the baseboard. 1. Is there a tool for this task? By the way, the existing baseboard is stained oak and the new door casing will be MDF. 2. If there is no tool for this, what do you recommend? |
- Posted by bobsmyuncle (My Page) on Wed, Jul 30, 08 at 16:38
| This is what most people use, as far as I'm aware. Get the "Flush cut saw blade" at the bottom of the page. If you are really good with a saw, you might be able do it with a Japanese-style saw. |
Here is a link that might be useful: FMM
- Posted by circuspeanut (My Page) on Thu, Jul 31, 08 at 0:13
| Another option is the Fein MultiMaster with a saw cutoff blade. |
- Posted by bobsmyuncle (My Page) on Thu, Jul 31, 08 at 8:18
| That's what I said... see the link. |
| To start the cut, tack a small piece of the new casing to the wall and use the edge as a guide for the blade. Once the cut is started the blade follows it easily. The Fein Multimaster is a great tool, but the blades are really $$! |
| it can be done with a saw zall also which cost considerably less than the Feim MM. You just need a sharp blade and a steady hand. |
