Finishing spallted sycamore.
Posted by jbander (My Page) on
Fri, Jul 27, 12 at 12:58
Thanks for the response , when using the minwax wood finish they suggest using a final Polyurethane finish over the top of it. I used it just by itself on a large grandmother clock and just left it it ,seems to be holding its own for about 10 years now. But I wanted a dry finish on the clock. I want a semi gloss on this table. When you used the Minwax wood Finnish dip you poly over it. My table has end grain spalted sycamore that I need to finish. My research says that first sycamore is hard to finish doesn't go on evenly it's blotchy and end grain wood when finished can be splotchy even more. some suggest a seal coat to keep it more even. What I want to do is use oil based Polyurethane with a percentage of Linseed oil mixed with mineral spirits to make it a rub on finish and put as many coats as I need for the finish I'm looking for and blochyness I'll concentration more finish on those parts until it is even. but should I use the Minwax first is my concern.
RE: Finishing spallted sycamore.
I took your response down to your original thread to eliminate confusion. Partially mine, since I couldn't figure out exactly what you were doing until I read other threads.
