Have you heard of a 'Dry' Glaze?
margieb2 (
Wed, Jul 11, 07 at 9:45
Has anyone heard of a glaze that is sprayed on, drys right away and then gets "dusted" off for lack of a better word? I was told by my cabinet maker that this form of glaze is more common now than the kind that stays wet longer and is wiped off. Should I be concerned?
-Margie
RE: Have you heard of a 'Dry' Glaze?
| Guess it's not all that common? ;-) |
| And that makes me just a little bit nervous! |
| By "dusted" he might mean 'lightly sanded.' I don't know much about any sort of glaze work, but this seems plausible to me. |
| I normally brush or wipe on glaze. This allows me to manipulate it to my liking. A year ago, a Mohawk salesman demonstrated an aerosol glaze for me. I was not too impressed with it, so I never followed up. (seemed like an answer for a question that no one asked.) I would not exactly have called it "dry" and it was meant for touch up work. Maybe these things are local? |
| Apparently Plain & Fancy uses this same glaze method. I believe it is wiped on and then brushed off as it drys rather quickly. Is it difficult or complicated to work with the traditional glaze? |
| Glazing is not hard to do. I use both oil- and water-based, depending upon what finishes I'm using. Most have a good open time, so you can manipulate the finish to your liking and if you don't like it, wipe it off and start over, add another color, etc. |
