Gently removing paint from dresser
Posted by bobina (My Page) on
Tue, Jul 3, 07 at 9:03
I have an old waterfall bedroom set. My mother in law painted the dresser (because she didn't know any better) blue years ago. It's not a thick layer of paint. Is there a safe and gentle way to remove the paint? I'm trying to avoid a complete stripping unless I have to.
Thanks.
RE: Gently removing paint from dresser
Strippers are so mild now as to be less harsh than sanding. In fact, an orange---environmentally friendly type----stripper may not even work.
That leaves scraping with any of several types of scrapers designed for removing paint. Those take an immense amount of elbow grease and can actually pull back muscles---from continually pushing down on the scraper as it is worked.
Or sanding. Paint clogs medium grit sandpaper very quickly. The fastest method is to use a coarse grit----40 or 80 grit in a random orbit sander--- the round sander that has stickon sandpaper. That can be very detrimental if the person using the sander does not have some experience. It is very easy to gouge a hole while sanding. That grit paper also makes scratches in the wood, which have to be removed by using finer sandpaper in steps---100 grit, then 150 grit. I seldom go over 150 grit if the wood is to be stained. If stain is not being used, the final sanding is done using 220 grit.
So, my advice is to use an environmental stripper first. The more paint you get off before sanding a very good thing. Get most of the paint off by stripping and you can start sanding with the 150 grit paper.
The paint left in cracks and tight spaces will have to be scraped out---any number of tools can be used there---I've used a flat screwdriver before. Whatever you have that fits the area and scrapes the paint.
Thanks for your help. I think I'll pick up a mild stripper and test it out.
I hear people all the time that want to scrape or sand instead of chemically strip. I know stripping is messy, but it's soon over and does a better job with less risk.
"A stripper knows where to stop." A sander or scraper does not.
N-Methyl Pyrrolidone
Look for a stripper with NMP instead of methylene chloride. Will work with less toxic fumes.
The waterfall furniture era was also the start of paper-thin veneer, so be super careful using sandpaper around it.
You also have to select your sandpaper wisely. There are papers designed for raw wood and others for paint prep. With the wrong kind, latex paint will ball up and leave a ragged surface, with the right one, it will feather out perfectly. It depends on the crystal shape of the abrasive particles, their orientation, spacing, adhesive and additives.
Casey
One of the cleaner methods for removing paint is a heat gun - like a hair dryer on steroids. It takes a little technique to determine the amount of heating (BEFORE the paint starts to turn brown/black.) But once you get the knack you can do it slowly and continuously down the entire length of a piece. There will be some left in the grain but it can be romoved thru sanding.
The Waterfall era which would be considered Deco and is most often Walnut does not have thin veneers.We refinish these pieces/sets many times a year.
I would strongly suggest staying away from a heat gun. You will at some point in using it, burn the wood. You will also never be able to get the paint out of the nooks and crannies as well as the grain.
You should use some sort of stripper like 5F5 . It's a goopy gell like consistancy ,it does a very nice job. Let it do the work for you .
You might need to use a brass bristled toothbrush once 99% of the paint is removed. This will allow you to get into the grain and remove that first layer of paint that got deep intot he wood.
Sanding with a random orbitla sander with a 220 grit should do the job. You might follow it up by hand with 220 after using the machine.
A quick summation is that you must strip the paint off, being gentle is really not a concern.The stripper will NOT hurt the wood.
Don't use a heat gun.
I'm going to be starting a refinishing project on a three-pc 1940's Waterfall set tomorrow, so this info has been helpful. My aunt had this set in her attic for several years, so there are thousands of tiny bubbles in the finish (not under the veneer). I was planning on using the F5F, but am wondering if I should use something less harsh and/or sand? I was worried about sanding veneer, because I thought it was only about 1/250" thick, but you seem to be saying not to worry as much as I am. I don't have a random orbital sander. Any specific recommendation for the tiny bubble issue?
BTW, does it matter if the finish is shellac, varnish or lacquer, for which you can tell I don't know the difference.
Thanks for any advice!
Use the 5F5 there is absolutley no reason to be concerned about it being harsh.I promise you the stripper I get in 55 Gallon drums is much harsher than any store bought product.
You won't be able to just sand of the paint,and definatley not by hand. IF you were to use an orbital sander the friction caused by the sander would make the paint and or finish cake up on the sandpaper. You actually do more damage this way.
Apply the stripper liberaly,let it work.
Keep repeating the process,use a spakle knife to get off the top layers of paint. A rough grit steel wool will help get it out of the grain or naybe a brass bristle toothbrush.
It all depends on how that first coat of paint adhered to the surface,it might come of nice and clean.
After the surface is clean of paint, wash it down with mineral spirits/ paint thinner.
Now sand the wood with a 220 grit paper ( you should use a random orbital sander) follow it up with a 220 grit by hand.
Now apply a clear coat of your choice, you will need to match the "white" wood sections of the piece to the natural walnut veneers. This might be tricky if your using an over the counter stain.The "white" wood sections are usually the "framework" of the piece.
Notice in the two pictures below that the feet on the vanity are not Walnut but stained a complementary color.
On the server, all of the leg sections are a "white" wood and again are stained a pleasing color to the rest of the piece.
Terrifically helpful, and gorgeous pieces Stocky! I'm looking now and see that my search for refinishing waterfall, even though I had "varnish" as a search word as well, yesterday brought me to this topic of removing "paint". I was so excited with the knowledge evident in these posts that I didn't notice.
I'm sorry that I didn't specify that it's only the original clear coat (varnish? shellac?) that I need to remove. However, in that case can I go right to the mineral spirits/paint thinner step, and the steps thereafter that you outlined above Stocky?
As 2 follow up questions...
- Is there a problem if I remove all the finish this weekend and leave it with it's bare wood for a 2-3 weeks or will humidity start getting under the veneer?
- What type of clear finish shall I use? Oil, varnish, lacquer? I see to stay away from water-based finishes and also that shellac can be tricky to work with. (I'm new to this GardenWeb site so should/will also move this discussion about finishes to another forum, but wanted to tap into what appears to be some great expertise on this one!)
Again, beautiful pieces Stocky.
Ok, so no paint, that's very good news and a heck of alot easier for you.
Use the 5F5 to remove the old finish.
Clean the surface with the mineral spirits
Sand
What to use for a clear finish is up to you. I spray lacquer via an ( air assisted /airless) syatem. lacquer is the least expensive,hardest,most user friendly finish you can use.
You would have to apply it with a brush or sray it out of numerous cans. We can discuss this part after the stripping is done.
Leaving the wood bare or raw will not do any harm to the veneer.
Remeber to wear a repirator when doing the stripping. It's about $25 from Home Depot type of store. You should do it outside and away from any flames or anything that can spark.
Thank you for the nice words on the pieces.
I can walk the thru the finishing steps when your ready.
Hi,
I had the same probplem. Ive stiped my night stand down and now im ready to start the finishing stage. But im not sure what stain or clear coat to use or even the color that most waterfall furnituer comes in. Can anyone help?
myles860, Hi, most "waterfall" style furniture is/was Walnut and in my opinon was meant to finished with a clear finish and no stain applied.
We spray our finishes ( from a high end type of system) so I'm not a good person to reccomend a brush on finish for ya, but if your only doing a night table you might want to look into a product that comes in a spray can called Deft . It's lacquer in a can. You might need 6-8 cans. IMO The finish will look 100 times better sprayed from a can than brushed on.
Hi,
It still has the walnut venner on it but the moldings on it are not made from walnut its a softer wood thats more white in color. fefor i started it all matched in color.
Yes, that style and for the most part when you have the beautiful veneers you have "white wood" used for your framework. This was the sort of standard as far as how things were built back in the day, with the exception of the hight quality stuff where the legs and framework would be the same wood as the veneers on the faces and tops.
As a layman you are going to have a bit of a tough time trying to get that white wood to match the Walnut. This holds especially true because your using a prepared stain out of a can , whereas in my shop we make our stains from pigment. It allows me to control the viscosity of the stain based on the needed application.
Hi,
Its me again, Ive found something close to the color I was able to mix a sligtly darker stain with it to make the color that was a near perfect match. Tomarrrow ill be breaking out the air compressor and spray gun and applieing my clear coat. Even without the clear coat its looks light years better than what it did when I got it. It has gone form being one of the uglest parts of my bedroom set to one of the better ones now. I almost wonder if i should do the beds now.
