| I have acquired an old bedroom set in fairly good condition, but the veneer on one dresser drawer front has lifted completely off in a single sheet. I'm looking for directions to successfully re-apply the veneer. Thanks for any help you can give me. |
- Posted by bobsmyuncle (My Page) on Mon, Jul 20, 09 at 18:25
| You may or may not be able to successfully re-apply the sheet. First off, I use hide glue as it was most certainly what was originally used on an antique and it will reactivate itself. You may be able to use the "liquid" version that does not require keeping the glue hot. Using this glue, then, rules out some unconventional options (contact cement, iron-on, etc.) Two complicating factors are If it's flat: If it's curved, you have more problems. This is often done by a process called "hammer veneering" where a veneer hammer is used like a squeegee to press the veneer down onto the hot glue while it gels and cools. But this really needs unfinished veneer. Another option would be to proceed as above, but use a vacuum veneer press to hold and clamp the veneer in place. This could be really tricky and may require you to disassemble the drawer front. |
