| I'm not sure if this will work and I've spent the last 2 days trying to Photoshop this on my PR walls using Adobe CS1. My brother installed it on my system and gave me a 60 second tour. I'm pretty computer literate but this program makes me feel like the village idiot.
I am trying to put picture frame faux wainscoting in my downstairs PR on the lower half of the walls. The design is a very simple box created by attaching four wooden boards above the baseboard and then placing a chair rail above the picture frame box. The confusing part is that this room has 5 walls of different sizes, plus a recessed area behind the sink. (Please see attached drawing). All the corners are bull nose. I don’t know if I should try and put the vertical boards of a box at each corner in the room (there are 9 corners) and create multiple different size boxes, or stay with a uniform spacing of the vertical boards for every box and cut/bend/attach the horizontal boards as needed to get around all of the corners. Will either or both look terrible? Is this room just a bad candidate for faux wainscoting? I posted a while back about this same PR after it was professionally staged and I was unhappy with the outcome. I've posted this in the home decorating forum and any advice would be greatly appreciated. Thank you for your help. |
| I would definitely expect there to be vertical frame members at every corner, with the size of each box varying to accommodate different wall lengths. In fact, I would expect there to be a vertical frame member on each side of each corner. The alternative of chopping up the horizontals to maintain a frame size that is unrelated to the dimensions of the room would strike me as silly. This is not wallpaper. |
| jon1270: Thanks for the advice. BTW I've never hung wallpaper but I think I get what you mean. |
