Tue, Jun 10, 08 at 22:54
| I have some Minwax wipe-on poly, clear satin finish with a little left in the can. I have a whole gallon of the brush on kind - same clear satin. Instead of going out and buying some more wipe-on, can't I thin down the brush on version (which I have plenty of). If so, how do I do it. |
- Posted by mike_kaiser (My Page) on Tue, Jun 10, 08 at 23:47
| Yes, with mineral spirits or naphtha but the latter evaporates more quickly. I'd start with a 2:1 ratio of poly to varnish and adjust from there. 1:1 might about do it. Just use some on a test piece before using it on any important. |
- Posted by bobsmyuncle (My Page) on Wed, Jun 11, 08 at 14:05
| Yes. I normally do a 1:1 with mineral spirits. It seems that the pre-canned version is a bit thinner than this, but what that means is it builds slower. One important note is the flattener that makes the "satin" finish will precipitate out of this thinned mixture much faster. Stir before thinning, stir thoroughly after thinning and stir frequently during application or you will find your first area much glossier than your last area. |
| Thanks guys - just the info I needed. |
