How do I make wood side rails for a full bed?
Posted by mrmarts (My Page) on
Thu, Jun 5, 08 at 21:25
I'm perplexed. I have an old headboard and footboard that at one time probably came with a nice set of wood rails. The rail slots in the headboard are just over 52" apart yet a full size mattress is 54" wide. How do you make rails that will fit the mattress? Won't the space between the rails be too narrow fo rthe mattress and boxspring to fit?
Thanks in advance for any help.
RE: How do I make wood side rails for a full bed?
Your bed is possibly 3/4 size, which is designed to accommodate a 48" wide mattress. Some of the second tier brands will still make a 48" set. Second tier does not mean second quality. Just means their name doesn't start with an S.
If you want to use a full size mattress, what you need to do is find an old mom-and-pop furniture store that also sells mattresses. Call and ask if you can purchase a "modi plate" from them. This will allow you to bolt rails to the plate, and then bolt the plate to the headboard and the footboard. You may want to consider a steel rail since its narrower and will probably get covered by a dust ruffle or sheets anyways.
Good Luck
It depends a lot on how the existing are hooked in and how much wiggle room you have. If the side rails are wood, the usual attachment is pin mount
If you can squeeze another 1.5" from the headboard / footboard, you may be able to remove them and retrofit a surface mount
