Best way to refinish this table damaged table top?
Posted by pfmastin (My Page) on
Wed, Jun 29, 11 at 21:14
This 8 year old table never had a good finish from the start...it was damaged when it was delivered and had to be repaired then. Over the years it's become scratched and rubbed but the most recent damage is the white area caused by a combination of a hot dish and a spilled glass of water. Can someone help me with what would be the best way to refinish it? Can I do it myself? Or should I call a professional? I don't know what kind of wood or if it is veneer or not. Thank you in advance.
RE: Best way to refinish this table damaged table top?
The first step is to identify what kind of finish os on the table.
Lacquer can sometimes be repaired by simply applying another coat of lacquer.
There's a scant possibility that the white is just in the very upper reaches of the finish and can be buffed out with rubbing compound, then waxed. Some people swear by toothpaste for this, but I use a auto body swirl mark remover. You'd have to polish the entire top to get it to have the fame sheen.
Casey
I use these (professionally) and have never had a problem removing a water blush in just a few minutes. You can also usually find them at Ace Hardware, Lowe's and Bed, Bath & Beyond in their cleaning / furniture care product aisle.
In my experience, rarely would you need to strip and refinish unless the finish is blistered and peeling off (I can't tell from the photo)
Likewise, you may need to buff out the whole top to even the sheen. The cloth will also remove light scuffing. Clean up the residual oil with an emulsion furniture polish
Here is a link that might be useful: water ring removal cloth
