Backboard for bookcase
Posted by momb57 (My Page) on
Sat, Jun 23, 12 at 10:10
I have been assembling bookcases to use as a base. I then connect and add wood trim. I am not happy with the "backboard that came with these shelving units. It is cardboard laminate that has been folded,creased and with perforations for cords - ugly. I want to add a wood grain material And then custom stain to match the finish and wood trim. But need something thin it needs to cover a 30" x 70" area. What is the best material to use?
RE: Backboard for bookcase
Thinner plywood usually does well.
The veneer appearance is often not that critical since the books block most of the visibility, but Constantin's sells large pieces of pressure sensitive wood veneer if you need to match something up (and are willing to pay).
It can take some experimenting to get a finish that matches close enough ion color, but between pigment stains and aniline dye you can make the general color match usually, if not the figure of the wood.
Thin plywood. You can usually find 1/4" rotary saw red oak at your local big box store. If you want anything else, you'll need a specialty wood supplier.
Then stain/finish it to match the rest of the bookcase.
