| Hi,
I am painting my bathroom vanity and was wondering how to seal it best. Is there a type of wax to use, or is it just poly. They were standard oak builders cabinets, I first sanded, primed with zinzer (sp) then applied behr Bitter Chocolate, so far 2 coats. I just lightly sanded and will do a third coat. I want to gently distress then seal in some way. I will try to post pics. Thanks, Laura |
| Why do you think it needs to be sealed? |
| I guess it is just habit! Not that it sees much moisture. Just wanted to protect it. |
| That's what the paint is for ;-) A friend of mine is a pretty good finisher and for years was publisher / editor of a woodworking magazine. He told me once, "There's a reason why you don't see people putting polyurethane over the paint on the outside of their houses." Wax is not really waterproof. The fact that water beads up on it is a matter of surface tension. Water does still get through unless it's really thick. One of poly's weaknesses is adhesion. You risk creating more of a mess if adhesion fails. The only time I put clear finish over "paint" is when I'm glazing a painted (lacquer) finish and need to lock down the glaze and adjust the sheen with a coat of clear lacquer. |
| Ok, then I guess I am fine! I will have to post the pics when I am done. Just need to hang the doors and put on the hardware. Then add a bit of distressing and wear. Hope it turns out all right! Thanks, Laura |
| Looks like you've done a fine job. |
| kmealy.....I want to do something similar to our oak vanity! I also wanted to change the countertop, though and was wondering what kind of tile that is you used....it looks great! Did you build a whole new countertop or did you cover what was there? Can't wait to see pics of the finished project! Thanks! |
| Sorry I never posted pics when it was finished! The tile is granite, sorry I can't remember the name. We took off the faux marble top and rebuilt for the tile. Looking at maybe doing the same finish to a desk I bought at the consignment store. So far it has worked well. Laura |
| The granite tile is really nice! I've been thinking about doing that for our bathroom. I don't want to do a major renovation and it would be too small an order to have a slab granite counter made (too $$, too!). You did a beautiful job on those edges. Was it hard to do? I’ve done a ceramic tile counter in my old house. Did you use thick plywood as a base for it? The tile looks good with those drop in sinks. The whole job looks nice. I have formica cabinets in my bathroom, unfortunately. So no refinishing will be possible. I still have to figure out what to do about those. I really don’t want to get all new. |
