Mon, May 14, 12 at 17:03
| Ok so I want to build a corner reading nook/stage without the cushion. I came up with this using 2x4s and 2x6's, does it look like there will be enough support for standing/jumping?
Thank you in advance! |
- Posted by sombreuil_mongrel (My Page) on Mon, May 14, 12 at 21:23
| Not viable if you run the flooring as drawn; if you break the flooring on the center radial support in a chevron "V" pattern, OK. If you keep the flooring as is and run the supports perpendicular (not radially as drawn) OK. Casey |
| Thank you Casey! I wanted to do like, a book shelf, book storage underneath a foot tall andndeep, which is why it's radial. The top can change, what does break the flooring on the radial mean? |
