Installing glass into cabinet doors
Posted by mileaday (My Page) on
Wed, May 12, 10 at 13:04
I inherited an oak glass front cabinet which is over 100 years old. I stripped away layer upon layer of finish to reveal a beautiful piece of furniture that holds many family memories. There are 3 glass inserted doors that I'm not quite sure how to finish. Two have curved glass and the 3rd has an 18" square piece. I checked with the local glass co. which did my kitchen glass front cabinets but they want $60 per door to install the original glass which is more than I am able to spend at the present time. What is the best do it yourself method for holding the glass? These doors would be locked and only openend once in a blue moon. I thought silicone but I don't want to mess anything up since I have put so much work into it already. Thanks for your help.
RE: Installing glass into cabinet doors
You don't mention the original installation method, but can you mimic that?
Otherwise I'd recommend something simple like capturing the panes with quarter-round or another appropriately shaped and sized molding. It should be flexible enough to follow the curves. Or it could be kerfed to help it follow the bends.
I have an old oak cabinet, the center door is arched. The original pieces used to capture the lites don't follow the curves perfectly.
Here's a photo of the inside of the door, you can see how the small ogee trim pieces have pulled away from the curved muntins. There are four ogee pieces per lite, each is held in place with a single brad.
