| My dad always said I should loosen coping/hacksaw blades after use. Never seen this recommendation elsewhere. Anybody else do this/heard of it? |
| Heard itm seldom do it. Even with bandsaw blades. But, I use Timberwolf bandsaw blades which are tensioned by the flutter methoid and are not under a lot of tension in the first place. I think the point is to relieve the tension in the metal when not being used. That might have been a good thing years ago when steel was of lesser quality and teeth treatments could actually weaken a metal blade. Not so much any more. I think I have broken two bandsaw blades in 10 years. And those were 1/8" or 1/4" sizes. |
| Bandsaw blades need to be loosened to prevent compression of the tires on the wheels. It the tires get a compression set the blade tension will vary as the wheel rotates and cause poor cutting and wander. Hacksaws and coping saws are fine either way since they are normally all metal affairs anyway. |
- Posted by daveinjersey (My Page) on Sat, Apr 16, 11 at 11:37
| Thanks to both. |
| I must not be using my bandsaw eouugh. I went to the manufacturers website and found this: "ALWAYS DETENSION YOUR BANDS I bought new tires for my saw from them. The blades have been on the saw for over 8 years---never having been detensioned except for changing blades. And then retensioned using their recommended flutter technique. Hmmmm. |
| The thermal expansion of steel is 6.45e-6 inch/(inch-F) A 111 inch bandsaw blade expands 0.000716 inches/F. Not a significant an mount compared to the compression available in the tire. |
- Posted by sombreuil_mongrel (My Page) on Sun, Apr 17, 11 at 12:29
| You really don't want your band saw wheels failing explosively, so this is probably excellent advice, and potentially lifesaving. I'm going to the basement now to loosen mine, which has been under constant tension for 25 years. Ugh. Casey |
| Yeah, me, too, neither. I have read for years of the detensioning advice. In fact, there are several detensioner attachments to more easily do that. Instead of loosening the adjusting wheel and vounting the turns. I bought tires and blades from Suffolk---no detensioning and no problems. |
