pressure treated wood for garage door jamb?
Posted by ncounty (My Page) on
Wed, Apr 8, 09 at 15:37
I need to replace my garage door and the door jamb which has termite rot. I am redoing the exterior of the house in stucco and putting in smooth metal doors to minimize maintenance and termite exposure. I am told they would use Douglas fir for the door jambs and I inquired about using pressure treated wood. Ideally, I would like it painted white.
I was told that pressure treated wood would not be aesthetically pleasing. My main concern on researching this is that it may be difficult to paint it white. Any thoughts on what material or wood type I should use? Thanks.
RE: pressure treated wood for garage door jamb?
As long as the PT wood is dry---easily verified by simply picking up a piece of dry and a piece of wet---the difference is HUGE---use a shellac based primer(BIN or Bullseye 123 by Zinsser) and whatever paint you choose. Painted PT wood looks no different than painted Douglas fir. Actually, if you are having a professional do the framing, they should be able to get CCA treated wood---it is still available.
thanks handymac....the install is next monday. I think they are going to try to use Azek which is even longer lasting.
Also, i won't have to paint it since it is already white.
