I'm planning on using some leftover pieces of Ipe to make a simple wall-mounted vanity for a powder room I'm adding to my house. Here's a concept image:
I was thinking about having it made from a scrap of granite so I've built a template of OSB to get the size exact. But now that I'm thinking that wood would be easier, cheaper, and better looking, and able to be done by me. I plan to use the OSB template as a substrate beneath the Ipe, and glue up the Ipe pieces edge to edge and then attach them to the substrate. My questions are: What should I use to glue the boards together edge to edge? Once its together, what should I use to finish it given that its a bathroom, and it will get a little wet at times? |
| The finish is the least of your problems -- you can't do what you're thinking of doing if you want it to hold together. Laminating a layer of solid wood, which expands and contracts with changes in moisture content, to an engineered substrate, which is dimensionally stable, is a recipe for buckling and delamination. You could use veneer, typically 1/16" or less thick, but OSB is a lousy veneer substrate. A wooden construction that looks like this is possible, but I doubt it will be so easy and cheap as you imagine. |
| Bob, as long as you are attaching the Ipe to the OSB with a few screws only, I don't see where this would be a problem. Jon is right that trying to laminate the two could cause problems. However, I really don't see the benefit of using the OSB as a substrate in the first place. Since this top will only be seen from above, I would use pocket screws on the underside to reinforce the edge-glue-up of the boards. Additionally, I would be sure to wipe down the ipe with acetone before gluing up the panel, and I would use epoxy for the glue-up since this will be in a wet area. This should give you plenty of strength to the joint, so as long as the ipe is strong enough for the application, there is little need for a substrate. If you do need a substrate, I would go with 3/4 CDX ply instead of OSB, just because OSB is not good in a wet environment. For a finish, I would probably use either a two part epoxy for its water-repelling properties or Behlen's Rockhard. |
