Thu, Apr 21, 11 at 12:20
| "a glass sweated and left a ring" Either shellac or lacquer. Lacquer is usually a little more water resistant but can blush if it is not thick enough on the surface. Just about any varnish is reasonable water resistant. The underside of the table should have the same finish. Use a cotton swab and some denatured alcohol on the underside to see if any of the finish comes off on the swab. If nothing happens, it is probably lacquer. You can do the same test with lacquer thinner.
