Hand tools ok to cut half-lap joints in 2x4 material?
Posted by phelansmom (My Page) on
Sat, Apr 23, 11 at 9:46
I am building raised garden beds. Found a plan I really like that uses half lap joints for the corners plus rebar or pins in the corners for extra stability.
I only have a circular saw and power drill and most instructions are for table or radial saws.
Is it possible to use only a tenon saw and chisel to complete this project an 2x4 redwood material?
RE: Hand tools ok to cut half-lap joints in 2x4 material?
People worked with wood for thousands of years before the advent of electricity.
A quick Google search turned up a video that uses a circular saw to save some time. No reason you couldn't use a hand saw instead. There's a You Tube video using a hand saw here.
Or set the circular saw to the correct depth, make repeated cuts, and then clan up with a chisel.
