Helical Planer
Posted by edwena (My Page) on
Mon, Mar 16, 09 at 19:13
Has anyone used a helical planer. Are there many on the market? The only two I have seen are Powermatic and Steel City. The powermatic models that I am aware of are out of my price range. Steel City has a new table top planer. I am wondering how it compares to the rigid tabletop planer in quality of output. Has anyone used one/seen one?
Thanks
Ewena
RE: Helical Planer
Woodmaster has spiral cutting heads as an option.
Supposed to produce a smoother cut but I have no experience with them.
I sure would like to own a Woodmaster planer/molder/gangsaw/sander.
All the planers I have ever used had straight blades.
Pooh Bear
Here is a link that might be useful: Woodmaster Planers
RE: Helical Planer
I don't have any experience with Helical heads, but I have sharpened a lot of planer knives. The idea of rotating an insert when you get a nick, rather than dealing with re-sharpening the entire knife is very appealing.
RE: Helical Planer
You might check over at Woodweb's solid wood machining section. I've never used a helical planer either. I've heard of two types - one with a thin, flexible blade that wraps part-way around the cutterhead, and another that uses many small insert blades like Blindstar mentioned. From what I've read, the latter type is good at minimizing tearout but is prone to leave a poorer surface finish than a straight-knife planer. I get the impression that they're better suited to heavy roughing cuts than nice finish work.
