Anyone with BOSCH 1617 Router - centering question
Posted by poorowner (My Page) on
Wed, Feb 4, 09 at 19:42
I bought a circle jig and it require you to take off the original mounting plate of the plunge base. I am afraid I can't put it back on center properly. The manual says you COULD use those tapered screws to center the plate and it will be "very close to centered"
I looked at those holes for the screws, and they won't thread in with where the factory set it (hope this makes sense).. so I am afraid to use this method.
They sell a centering cone also, is that going to work better? Do I need a template guide to use the centering cone? I think it's BS that you have to pay extra to center your router?
RE: Anyone with BOSCH 1617 Router - centering question
What kind of circle jig? Is it the one that pivots the entire router around a fixed center point, like for cutting round table tops?
The only time you need to have the router bit perfectly centered in the base plate is when using a guide bushing to trace a jig, like cutting dovetails. I center it visually during setup. Put the guide bushing on the base plate and the base plate loosely on the router base. Insert the router bit through the guide bushing and into the router collet and tighten. With the bit tight in the router, you can visually center the base plate by looking at the tiny gap between the bushing and bit.
Yes, the centering bit will work quite well.
The centering is required when changing base plates, since the manufacturer cannot guarantee the different base plate makers---you can even make your own baseplates----will get the plates centered.
