Need advice re: installing wall-mounted bookshelves
Posted by ninjabeans (My Page) on
Fri, Feb 15, 13 at 11:00
Hi all - I recently moved into a rental apartment and had some long wood shelves made that I would like to install on a long living room wall for all my books. The shelves are 1" thick pine, and 3 of them are 6'-8" and one is 8'-8". The wall is 5/8" sheetrock on what I was told was a full 3-5/8" metal stud, about 16" on center. The brackets are heavy metal 10"x10"x1/4"th galvanized steel I got from McMaster-Carr w/ 4 screw holes on each to attach to the wall.
My question is - if I install in the studs, do I need a wall anchor? If so, what kind? Is this even advisable? I was told I should rip out parts of the wall to install wood blocking - this is a rental and I just painted that wall, so that's REALLY not an option.
Any advice would be SUPER helpful. THANKS!!!!
RE: Need advice re: installing wall-mounted bookshelves
The problem is that anchoring to even steel studs will not take all them much weight without blocking to spread the load over a larger area.
The folded edge of the stud will flex under load and the drywall start to crack around the attachment points.
Bookcases would likely be a better option, or some vertical supports to the floor from the shelves to transfer some of the load.
Even relatively small cross sections of hardwood usually have a high load capacity vertically.
You could use small 'posts' at the front and back of the shelves to get weight to a lower shelf, and finally to the floor preserving a lot of the 'open' appearance.
Even a 1 inch x 2 inch 'post' from a decent hardwood has incredible vertical load strength (parallel to the 'grain'.
You do not need 2x4s hardwood sections for something like this.
You really need to contact your landlord before either painting or drilling into the walls. Most would have a conniption fit and initiate eviction ASAP. And don't think that he won't find out either.
Thanks but the landlord knows all about it.
