| I am going in 2 different directions for my Island countertop. There won't be a sink. I have read a lot about Waterlox and see that is a good direction.
However, if we decide we want to cut on it (probably a portion of it) we are also researching oil. Also, I just love the natural look of the wood. Nothing shiny. I did do a sample of Waterlox on a cutting board. It looks really nice- but I don't know if we want the "furniture look". I am aware you wouldn't cut on the WL. SO, I've been reading about tung oil/citrus blend that DeVos Woodworking recommends. It's from Milk Paint Co. (actually 2 products I believe that you mix together. http://www.realmilkpaint.com/oil.html
I also was told by DeVos that if you have the tung oil finish and decide you want to Waterlox you can put the WL over it after a few weeks without sanding down to bare like you would do with mineral oil. From the DeVos site: Tung Oil/Citrus Finish (recommended for tops used as cutting surfaces) We highly recommend the Tung Oil/Citrus finish over the mineral oil finish for tops that will be used as cutting surfaces. Pure tung oil is FDA approved and non-toxic by nature. Citrus solvent, which is 98% orange peel oil and 2% water, is added to tung oil to hasten the drying process and deepen the penetration of the oil into the wood. The oil penetrating into the wood makes the surface resistant to water and chemical damage. Surfaces treated with the Tung Oil/Citrus finish have an overall matte quality while still retaining their natural appearance. DeVos Custom Woodworking applies four coats of the Tung Oil/Citrus finish to ensure a well-oiled finish. Another advantage of using this finish is that the finish only needs to be renewed about every six months to a year, depending on usage, as opposed to a mineral oil finish that needs monthly attention. *Any thoughts? : ) |
- Posted by bobsmyuncle (My Page) on Wed, Feb 15, 12 at 17:11
| Pure tung oil is FDA approved and non-toxic by nature. > FDA, as far as I know does not "approve" any finish. And when was the last time you heard about someone getting sick from "finish poisoning?" Lead in finishes/paints was banned in USA in the 1970s. Citrus solvent, which is 98% orange peel oil and 2% water, > What would you think if they called this a "hydrocarbon cyclic terpene, d-limonene?" This acts like a thinner and evaporates away? All that said, it does not sound like a bad product, you're just getting schmoozed. |
| Behlen Salad Bowl Finish is formulated to meet CFR21, 175.300. The FDA establish standards, but most are aimed at commercial kitchens. Even the cleaning chemicals must meet the FDA rules for commercial use. |
| [Code of Federal Regulations] [Title 21, Volume 3] [Revised as of April 1, 2011] [CITE: 21CFR175.300] PART 175 -- INDIRECT FOOD ADDITIVES: ADHESIVES AND COMPONENTS OF COATINGS Subpart C--Substances for Use as Components of Coatings Resinous and polymeric coatings may be safely used as the food-contact surface of articles intended for use in producing, manufacturing, packing, processing, preparing, treating, packaging, transporting, or holding food, in accordance with the following prescribed conditions:...
Here is a link that might be useful: TITLE 21, PART 175
- Posted by 2LittleFishies (My Page) on Thu, Feb 16, 12 at 12:02
| Can you cut on the Salad Bowl FinisH? I'm referring to safety as well as not ruining the surface and being able to refinish with more finish as you would with oil. I'm told tung builds up a finish... is that good for cutting? So far most are just recommending mineral oil... I don't love the way Waterlox looks. Beautiful but it looks like it's "finished" (I used 3 coats 50/50 or original/satin and 1 satin). It also gave a very slight amber color to the walnut. If there's another protective finish that is less maintenance than mineral oil (that doesn't look so much like furniture) I'd consider using a cutting board for cutting. I want something very matte... I was in a rush typing this. Hope I made some sense! Thanks! |
- Posted by 2LittleFishies (My Page) on Thu, Feb 16, 12 at 17:27
| Is the Salad Bowl Finish more Matte than Satin Waterlox? Does it alter the wood color? I assume you wouldn't cut on it intentionally- even if it is food safe? |
- Posted by bobsmyuncle (My Page) on Thu, Feb 16, 12 at 18:52
| The Salad Bowl finishes that I'm familiar with are simply varnishes. They form films, so you would destroy the integrity of the finish if you cut on them. Water will penetrate the cuts and cause the finish to fail. You can add wax to mineral oil to boost it. About 1 part wax (paraffin) to 6 parts oil, heated in a double boiler until the wax melts. |
- Posted by 2LittleFishies (My Page) on Thu, Feb 16, 12 at 22:37
| A wood countertop guy in Michigan said they use Sherwin Williams lacquer on their countertops if you're not going to cut on them... What do you think? " It is used for restaurant tables, counter tops and islands where the primary use is for service purposes and not for direct cutting. It is available in matt or what sherwin calls dull rub, semi gloss and gloss. 99% of all our blocks using a hard surface finish use the dull rub laquer. The catalyst adds hardness. It is water and stain resistant like waterlox but unlike waterlox it is hard and clear. Waterlox yellows the block. Most people who have hard surface finishes use a cutting matt or block and store it under the top or in a drawer. " http://oem.sherwin-williams.com/ca/eng/oem/products/sherwood_catalyzed _lacquer/?referringCategory=categories/wood/finishes_topcoats/ |
Here is a link that might be useful: SW Catalyzed Lacquer
- Posted by 2LittleFishies (My Page) on Fri, Feb 17, 12 at 10:27
| bobsmyuncle- One more thing... Then, According to the link you posted on another discussion (below) Waterlox and Salad Bowl Finish are basically both wiping varnishes but perhaps give a different finish (matte/semi-gloss?? Both are oil/varnish blends? I can see the marketing of all these different products is confusing. If you get a bad scratch in any of these, are you able to sand down the one area and refinish like you would with oil? |
Here is a link that might be useful: finishes
| Any finish that forms a film will fail in short order if cutting is done on the surface. About the only thing you can use is mineral oil. If you scrub the surface hard with soap the mineral oil is basically removed. Adding wax to the mineral oil makes a thicker layer, but it is still not an actual film of cured finish. Mineral oil is available at the drugstore.
- Posted by 2LittleFishies (My Page) on Fri, Feb 17, 12 at 15:25
| Brickeye- thanks for your time, but I do know all of that information. : ) It's always good to hear it again though! My other option is NOT to cut on the board and if I decide to go that route I'm comparing various finishes. Ideally, one that is the most matte and looks like the real wood. The waterlox gave an slight amber color to my walnut board (I can compare both sides). SO, maybe the salad bowl finish or the Sherwin Williams one that one of the butcher block people uses (above). |
- Posted by sombreuil_mongrel (My Page) on Sat, Feb 18, 12 at 11:01
| Hi, I have used both the salad-bowl finish and the waterlox original. (as well as pure tung oil) Waterlox original, brushed on, is quite reflective, but not as shiny as a full-gloss varnish. I'd say it's 90%; if wiped-on more like 70%. Is more forgiving of a rougher sanding job, because there is a thick finish on the wood. 240 grit will suffice. Salad bowl finish is satin gloss, 50%. It is very thin and slow to build, the four coat recommendation should be followed. And if course if you really cut on it you will wreck it, and go right through to the wood, which can then stain through the cuts. Requires a good deal of prep, sand through 320 grit at least. Pure tung oil dries very flat, no more than 10% reflective, demands a very well-prepped surface (sand to 400 or 600) because it does not form a surface film, it will not fill in any sanding scratches, only exacerbate them. Best application involves applying a puddle of oil, then sanding it in with 600 grit abrasive for the ultimate smoothest finish. Very effective technique for walnut, because it helps fill the pores with wood dust/oil slurry. Casey |
| If you apply enough coats of tung oil is will build a film. |
- Posted by 2LittleFishies (My Page) on Sat, Feb 18, 12 at 15:23
| Thanks for the info! I'd love to know your thoughts on the sherwin Williams lacquer?? Dull rub. As far as looks, wear, if it had to be reapplied, repairing scratches. |
- Posted by bobsmyuncle (My Page) on Sun, Feb 19, 12 at 18:16
| So many questions here Oil finishes or oil-varnish blends do not build films well. That is why they are "in the wood" and duller finishes. Trying to build a film with an oil finish is likely to give you a soft, wrinkly and sticky surface. Sheen While various companies use different adjectives to describe their products' sheen, for example, high gloss, gloss, satin, eggshell, flat, dead flat, these are not industry standardized terms. I've even seen one company's two different products that have a different sheen for what they label "satin." The sheen is graded on a 0-100 scale from flat to high gloss. A finish out of the can is not likely to exceed 85 to 90 degree sheen, but you can buff to a higher gloss finish. S-W finish Color In short, there is no perfect finish. Each has certain characteristics such as appearance, color, sheen, enhancement of wood grain or chatoyance, protection against chemicals, protection against UV, protection against water(yes I know water is a chemical), protection against abrasion or other physical damage, dry time, odor, ease of repair, ease of application, your ability to successfully apply, maintenance requirements, cost, etc. When I teach finishing classes, I always say you pick the one or two characteristics most important to you and with that finish you get the concomitant characteristics that come with your choice. |
- Posted by 2LittleFishies (My Page) on Sun, Feb 19, 12 at 18:26
| Great information, bobsmyuncle! With the Sherwin Williams, the woodworker would be spraying the island top in his workshop so I don't need to worry about fumes, pot life, or size availability. What I DO want to know is how this type of finish wears and how it protects? Also, How it compares to a Waterlox type product (that so many love). In short, would you recommend it? Someone on the kitchen forum said this: "I really don't understand that, 2LittleFishies. Catalyzed lacquers are generally not great for anything that's going to come into contact with water, so I'm not sure about what they're saying. If you set a damp glass on a lacquered table, it will leave a ring if it sits there long enough. It's water resistant, but it's water resistant the way a nylon windbreaker is water resistant. So unless they're talking about something pretty different from normal catalyzed lacquers, I'd stay away. I've used other lacquers for other purposes and I can tell you they take a lot of rubbing out to get the finish really smooth. They say it's similar to a nitrocellulose lacquer in how it behaves. I'd use those for cabinets but not for a countertop, myself. I see they don't say 'countertops' in their list of applications for it." |
| I use mineral oil on my wood counter tops, both cutting and non-cutting surfaces. No nonsense, easy to apply, easy to renew. I renew it maybe every 4-6 months. Wipe on at night, wipe down in the morning. I've also uses mineral oil and beeswax, at a 5:1 ratio. Heat over stove (careful) then wipe on and lightly buff off. Works great, looks purdy...but straight mineral oil is fine for me. |
| The issue with cutting boards or a counter you plam on cutting directly on is that ANY finish that forms a film by hardening is going to be damaged by cutting. Moisture then penetrates through the cuts in the film, spreads in the wood, and weakens the finish around the cut. Cutting boards have classically had non-film oil type finishes. It is not very hard to 'replenish' though. |
| OK, if you care about the appearance of your island, as in you don't want to see stains or scratches, you should NOT EVER cut on it, or let staining foods (tomatoes, berries, beets, spinach, etc) touch it. If you have used an unfinished wood cutting board, you know how they get stained, cut, and can warp and split. The same will happen to your island top. Mineral oil is NOT a finish; it provides nearly no protection, even when freshly applied, and disappears rapidly. It briefly darkens the wood as it soaks in, before it disappears. With my butcher block island, I probably oiled it every month to keep it looking nice (and that wasn't really enough). And I had to bleach out the stains. A finish that cures will keep the wood looking good much longer - on the order of years rather than weeks. Any of these finishes are safe; no cured resin or varnish is more or less safe than others. If you don't like orange/amber, you don't want Waterlox, which is made with phenolic resin. Starts out deep amber and will get even more orange with time. Minwax Wipeon Poly is a nice pale gold color, but poly is not as easily repaired. Real tung oil has good water resistance and pale color, but takes forever to cure. And it takes a lot of coats, with days of drying between each, to build up any protection. I would mix tung oil with alkyd varnish, which is a pale color and repairable, add some drier, and thin with mineral spirits. (As pointed out already, there is no advantage in using citrus solvent; it's just a different plant source of the same powerful, volatile type of solvent.) Then, once the finish has cured, rub out the gloss as dull as you please with sandpaper or automotive rubbing compound. There is a recipe for this finish on Fine Woodworking (Hot-rod Varnish). I finished a friend's cutting board with Minwax Wipeon Poly. She uses and cuts on it all the time. Of course the finish shows the cut marks -- but not quite as much as an unprotected (oiled) cutting board. The finish protects it from staining, which is what bothered her. It had pink-red stains from raspberries all over it when I got ahold of it. After several years, it has knife marks, but no stains, and the finish makes it much easier to keep clean. Even with cuts in the finish, it will warp less than a mineral-oiled board, because the finish keeps out far more water than mineral oil ever does. |
- Posted by hosenemesis (My Page) on Sat, Mar 17, 12 at 15:55
| I'm just a homeowner, not an expert like all of these people here on this forum, but I can share my experience. I had my pine cabinets done with a spray-on lacquer to keep the light color and avoid yellowing, which is has done well. What it doesn't do well (on a soft wood, anyway) is last. All of the top edges and the areas around the knobs is worn off- after only a few years. I am hard on things so that should be kept in mind, but still. I also have a lacquer on my stone floors, and that has been a catastrophe in the kitchen. It can't be touched up, and if it gets scratched it turns white. Water can get underneath it and turn it white. I would never use lacquer in a kitchen again, especially if you are tough on surfaces. I have a built-in chopping block that is 12 years old now and all I use is mineral oil every so often. That means just taking a rag and wiping it down. I wipe again in the morning- that's it. It looks like I use it for chopping- it has knife marks in it. As I understand it, the names of things do not tell you what they really are. I found this article to be enlightening- it tells you what is in different products. |
Here is a link that might be useful: Popular Woodworking article on finishes
- Posted by 2LittleFishies (My Page) on Sat, Mar 17, 12 at 16:00
| Thanks, Renee! So I'd love to hear more. Is your chopping block an island, or just a chopping block that use use for cutting? Do you think using mineral oil for the island would be something I'm happy with in comparison to your experience with the lacquers? I'm really leaning towards just doing mineral oil or oil with wax. I think if thinks get messed up I can just sand it a bit whereas with a "finish" it may get more tricky. I looked at my Waterloxed sample again today and really just don't like the yellowy look too much. |
- Posted by hosenemesis (My Page) on Sat, Mar 17, 12 at 20:55
| I really recommend just oiling it at first. If you don't like it, you can always seal it later. I would avoid lacquer finishes until you speak to someone who has done it and lived with it. My chopping block is next to the stove. It's only used for food prep. None of our counters were sealed for the first two years, and since we are both usually covered in dirt (DH an archaeologist and I'm a gardener and neither of us are housekeepers) they started to look grungy. We sanded them out and put a few coats of satin polyurethane on them. They are a little yellower, but it's much easier to keep them clean now. I would never put a lacquer on a surface that was going to get any use again. If you are inclined to do that, I would get a small piece of wood, lacquer it, and put a puddle of water on it for a few hours to see how it reacts. Renee |
| UNless you have spray equipment, you are going to need a brushing lacquer if you go that way. If you start with a gloss lacquer you can fiish it to any sheen level you want after the fact, but if you start with any other lacquer you cannot make it a higher gloss, but can still lower the gloss. Deft Clear Wood Finish is a brushing grade of lacquer. You will need a high quality brush, and likely some practice since even brushing lacquer dries VERY quickly. The first few coats can be the practice though. I actually prefer using it under shelter outside when the temperature is on the low 40s to slow the evaporation even more. Using it at any temperature above about 75 degrees will be a frustrating battle. It is also painfully flammable, and the vapors are even explosive in the right concentration. |
| Not sure if you're still checking responses.....I would use tung oil, but only the one avialble from the Real Milk Paint Company. I've come to dislike artificial wood finishes. We built a log home andd the whole interior is wood, including the floors. We used tung oil/citrus solvent on them. It's wonderful to not feel ill in this house and people comment on how they really like the natural look, and how fresh our home smells. We live hard in this house and have pets. If applied correctly (wood saturation point), the finish is easy to clean and durable, once cured. We like that it is renewable without having a nightmare stripping old stuff off.the downside is that it does take anywghere from 2-4 weeks to fully cure. With time, the finish becomes harder thereafter. I did some kitchen/pantry shelves with this process. Once fully cured, the surface is slick to touch and water beads up. I like the fact that pure tung oil is non toxic and my wood is natural looking with no outgassing.I will never go back to lacquers, polyurethanes, etc. |
- Posted by 2LittleFishies (My Page) on Thu, Jun 21, 12 at 20:05
| Thanks Sandy- We start our kitchen next week so no definite decisions are made but I was leaning towards the mineral oil and then see how it goes! I am interested in the tung oil from REal Milk Paint. It seems the drying time is an issue? Does that mean we wouldn't be able to use the island for a few weeks? Do you have any photos? Thanks! |
- Posted by bobsmyuncle (My Page) on Thu, Jun 21, 12 at 20:13
| "If applied correctly (wood saturation point)" Only a very shallow portion of the wood has ANY finish present. Once the wood pores and cells start to fill up, no more penetration occurs, just surface buildup and film forming. If you want to see how shallow the penetration actually is, cut into the wood and look at the edges of the cut. If you make a small cut with a sharp router bit the edges are often clean enough to see finish penetration clearly. |
