Tile trivets with wood molding edges
Posted by linnea56 (My Page) on
Wed, Jan 16, 08 at 15:00
I bought some hand-painted tiles. I want to use them as trivets and also be able to hang them up on the wall when not in use as decoration. I don’t want to re-invent the wheel, so I imagine someone here has made a lot of these and can advise me. I think I am making this way too complicated.
I plan on using some egg-and-dart oak molding that will tie in with other molding I have added in the kitchen. Under the tile itself I thought I would use some masonite or plywood. The tiles are a little thin, maybe 3/8 inch, so I think they need some backing. I’m not sure how I should attach the molding to the base, whether it should be recessed or whatever. If the base is recessed, I would have to nail through the sides of the molding: therefore the base material would have to be thicker. Or could make a corner block. The egg-and-dart molding is rather thick and substantial.
And should the tile just be glued in? Since it will conduct heat I need to have a glue that will not weaken with heat, so the tile won’t fall out when hanging someday.
For hanging I was thinking about using a keyhole-type insert. Is there anything that would be better? Thanks in advance!
RE: Tile trivets with wood molding edges
I have one of these that's 25 years old and used daily. I think you might be over analyzing. (Something I'm often guilty of). I just made a frame, cut a rabbet in the top and dropped the tile in with some glue. I probably just used yellow wood glue, but I can't really remember. Lately, I have started to use GOOP for a lot of mixed mode gluings. It keeps some flexibility and seems to hold well.
(I forgot to check the e-mail response box when posting so didn’t know anyone had answered)
Thanks for your response, bobsmyuncle.
I do overanalyze, that’s true. What concerns me is that I want to be able to hang it on the wall, so don’t want to have the tile drop out. Has anyone made a hanging one? I had not thought of Goop, I do have some. I don’t have the equipment to rabbet, but having a wooden base under the tile will work as well.
You could also use epoxy. A good one, like JB Weld is heat proof.
