Fri, Jan 6, 12 at 13:42
| If you are painting them anyway... MDF is standard paint grade material. A good paint job should look like a factory finish. Maple is just stronger wood and will tolerate some water. Painted Maple shows more surface defects than painted MDF. Maple requires extra prep work; more putty and 2 primer coats. |
- Posted by weedyacres (My Page) on Tue, Jan 10, 12 at 13:40
| So it sounds like MDF is more than OK, it's actually slightly preferable. Thanks. |
| It's a little bit less work to get a really nice paint job on MDF. I think most painters prefer it. The average person can't tell the difference after they're painted. Beyond that, I would not say MDF is preferrable. I rarely use the stuff because it's heavy, nasty to work with, and doesn't hold screws as well as ply or solid wood. |
- Posted by cabinetsbyalan (My Page) on Wed, Jan 11, 12 at 10:10
| I buy either from Conestoga door company. They have an mdf door with sharp inside corners. Some mdf doors have rounded inside corners and they don't look as nice. Mdf does paint real nice. |
