| Hi. I tried to do a search, but the search engine is apparently still down. So, my question is: My sister has a really cute little dining table, 4 chairs & a bench set that she's giving to me. It is finished in a light color, I would say Pine and I would like to refinish it in a darker oak color... How do I go about this?
The table has some nicks in it here & there & is quite dirty from being stored, so I know I need to give it a good cleaning, but what's best to use? It has a smooth finish, polyurethane (sp?) I assume, so do I need to strip this off or can I just sand? You'll have to excuse me, I'm a girl & don't know much about this kind of stuff, but I'm really excited to get started! OK, after the new stain is on, if I make it that far, what to you put over that for a protective finish? Poly? I really want to do this myself & do a good job, so if anyone can help me I'd appreciate it immensely! TIA! |
| Clean it up with mineral spirits on a cloth...on lots of cloths because you will toss them when theya re dirty...paper towel is good too. Unless it has been refinished, it's unlikely the finish is poly. To get a new stain to "take" you will have to completely remove any old finish. I recommend a commercial stripper from your paint store. You strip the pieces, sand everything, apply a new stain of your choice and apply 3 coats of finish, poly is good, rubbing with steel wool between coats. OR...you could do quick and easy...and clean the pieces up and apply a coat of darker colored varnish. BUT...when you chip or scratch the finish, it will show lighter beneath. The best way is to strip, sand, stain and finish...but you could get by for a few years with just a new coat of varnish. Linda C |
- Posted by bobsmyuncle (My Page) on Thu, Jan 31, 08 at 19:31
| I know a lot of professional finishers. Many of the best ones are women. I mostly agree with LindaC's comments except: |
Here is a link that might be useful: Cleaning a finish
| I've finished miles of wood surface and never had and steel wool shards left in the finish...in my fingers, yes but not in the finish. Of course I knew the possibility existed and so was very careful to remove all the stuff, use a tack cloth and wipe carefully And I too agree the colored varnishes may streak....I have tinted varnish with artist's oils...because that's what I had at the time. I found it worked well and repeated it the second time I wanted to darken a finish. It's a quick fix. I wish you would hang out some on the antiques forum and promote your ideas on finish preservation. There's someone there who believes any old finish should be removed, always, no question, and he says I am an idiot for suggesting that a lot of old finishes can be cleaned up and "patched" and waxed. Linda C |
| Did I hear my name mentioned ? Let's be clear about one thing, lindac is NOT a professional finisher. Linda why would you use steel wool between coats ? You called yourself an idiot not me. I don't like you because you run from forum to forum answering peoples questions like you are a Britanica Encyclopedia . Again, stick to what you know,it's clearly not wood types and how to refinish a piece of furniture. Again, I can't sell what your claiming is the answer to my customers.You don't seem to understand that.I can't guarantee my work if I were to go the route you always suggest. Try answering just one of my questions ?
- Posted by bobsmyuncle (My Page) on Fri, Feb 1, 08 at 18:47
| Um. I'm staying out of this one. |
| Um, OK, thanks for the replies. I'm sorry, didn't mean to get a fight started here... LOL. My DH & I are going to tackle this project in a couple of weeks, so if there are any more suggestions, I'd love to hear them. Thanks again! |
