Wiring dual lights for a brooder pen
Posted by BSB30120 (My Page) on
Wed, Dec 29, 10 at 18:21
I would like to wire 2 lights for my brooder pen (baby chicks). What I would like to do is have the first bulb be the primary heat source (250W bulb) and then, in the event this bulb burns out, the other comes on. Can someone help me with how to accomplish this??
Thanks
RE: Wiring dual lights for a brooder pen
Are they plain old 250w lamps? If so, maybe use a photocell to control the second lamp. As long as the first one is "on" the second will be off.
Wayne - impressively simple approach. May take a little trial and error with some sort of a "light pipe" on the photocell to prevent Lamp 2 from cycling on/off if Lamp 1 fails, but it could even be done using all off-the-shelf, plug-in components, and no hard-wiring.
One of these on lamp #2 could be all you need. As long as light #1 is on light #2 should stay off. $10 from home depot
Socket Adapter
The photocells are mounted so the bulbs they control don't shine directly on them. Sometimes if there's something reflective near by you can get the thing to start flickering because it sees it's own light, but usually you can apply some tape in strategic places to cut that out.
