| BEFORE:
-1 single pole wall switch with a single 12-2 romex wire going to it (B/W/G). No other wires in the wall box. -The switch controls a single outlet which I leave "always on" (I taped the switch in the "ON" position). AFTER:
QUESTION:
Is this along the right idea?
Basically, I need a power supply to tap from, can't that be the wire that is currently connected to my wall switch? |
- Posted by mike_kaiser (My Page) on Wed, Dec 9, 09 at 16:15
| Let's start with what you have now. Since there are no other wires/cables in the switch box, the power is being fed from the switched receptacle. It goes out of the box with the receptacle via the black wire, through the switch, and back on the white wire. If you want the switched half of the receptacle to stay on, you can just wire nut the black and white together. If it you do that might not be a bad idea to get a black Sharpie and color the last couple of inches of the white wire so that in the future whomever goes in that box knows what's going on. Pull the switch and tuck the wires neatly in the back of the box. The other option involves understanding what happens when you switch one half of a receptacle. There is a little brass tab that connects the two screws. That tab is broken off and then the receptacle is wired. The easiest thing to do is simply replace the switched receptacle with a new one, leaving the wires that go to the switch disconnected, capped, and tucked neatly in the back of the box. The other option would be to use some short pieces of wire to kind of "jump" to the now switched side of the receptacle. What you didn't say, is how you are planning on powering these new, recessed cans. One option might be to use the existing cable running from the switched receptacle to the switch to bring power to that box and then on to the new cans. Let us know your thoughts and we can take it from there. |
| I just picked up a ceiling hole cutter from a friend and he explained exactly what you did about the brass tab being broken off. I wanted to get power exactly as you mention, from the existing cable running from the switched receptacle. Be basically said what I think you are saying which is: That should take care of it all, right? |
- Posted by mike_kaiser (My Page) on Wed, Dec 9, 09 at 21:46
| Sound pretty good except for the old receptacle. My personal preference is not to wire through a device. In your case, if you use a "jump" wire, where are you planning on connecting the EXISTING cable? Can't put two wires under the screw. Either use a new receptacle or use pigtails. If the boxes are metal, you'll want to ground those was well as the devices. |
| Makes sense mike (about pigtailing or using new outlet), but there's actually a little change that may make things easier: I just opened the outlet. Both brass tabs are intact, 2 incoming Romex wires, nothing else. Single black from Romex1 going to top outlet brass screw and single white from Romex2 going to top outlet white screw. Outlet & box are grounded via both wires. Remaining white from Romex1 and remaining black from Romex2 are wire-nutted together. Nothing is coded black. Is this how I proceed? (Power will be off at circuit breaker during everything except testing) 2. Keep POWER romex connected to brass/white screws on outlet. Connect NON-POWER romex to bottom brass/white screws. Keep all grounds grounded as they were previously (with outlet & wall box both grounded via green screw on outlet and green clip on wall box). 3. No pigtailing is necessary. No coding of wires is necessary. -->The above steps should now have the outlet "always on" via the top 2 terminals and I should have outgoing power now to my new dimmer switch via the EXISTING (or NON-POWER which I just turned into a POWER) romex. This all correct? |
- Posted by mike_kaiser (My Page) on Thu, Dec 10, 09 at 8:12
| Sorry about the confusion with the brass tab. It's pretty common to switch only half of a receptacle. In your case, they switched in the entire receptacle, which makes your life a little easier. Romex 2 is what's bringing the power in. Romex1 takes the power to the switch (and back). As for your plan, it's fine. As I said, I prefer not to wire through devices but there's nothing that says you can't. |
| You are correct. However it is simpler than you are making it. Just connect the two blacks to the brass screws and the two whites to the silver screws. It does not matter whether power is on the top or the bottom screw. |
| Great, will just to blacks to brass and whites to silver. Mike - Why do you prefer not to wire through devices? Just curious, and thanks for clarifying that technically, I CAN do it. |
