Treadmill turns lights on.
Posted by hendricus (My Page) on
Thu, Dec 3, 09 at 14:29
Garage lights are on a motion sensor.
Treadmill is in a utility room behind the garage proper.
Probably on the same circuit.
Sensor is in a different room than the treadmill.
About one minute after starting the motor on the treadmill the garage lights come on. How come?
RE: Treadmill turns lights on.
Most likely Electro Magnetic Interference (EMI) from the DC brush motor in the treadmill coupling into the sensor circuitry.
Get a battery operated AM radio and tune it between stations.
Turn the treadmill on and off and see if you detect a change in the noise from the radio.
If the noise is bad enough, it may even be able to be heard when the radio is tuned to a station.
If you can identify wiring for the sensor you can try and wrap it with some aluminum foil.
Even without grounding the foil sometimes you can block enough of the electrical noise to eliminate the problem.
