Broken socket
Posted by pump_toad (My Page) on
Mon, Dec 21, 09 at 12:46
I am sure this is a very dumb question but I need to ask for my peace of mind.I was throwing a blanket up to a shelf in a closet and hit a old fashioned light socket. The bulb fell out and I notice the socket is split.I tried the bulb and it does light but I don't want to use it that way. Have taken the bulb out so want to know if it is safe that way until I call a electrican.
Lois
RE: Broken socket
It's very likely safe. The main thing to worry about is if a wire got detached or moved, but I doubt that that would happen just by cracking the socket. However, when you say the bulb fell out, do you mean the whole thing, including the base of the bulb?...because that could be a more serious problem indicating greater damage. If you do have major damage, it would be best if you could throw the breaker for that light until the electrician shows up.
RE: Broken socket
I think a deeper issue is the presence of an open lampholder in a clothes closet.
bad, bad, bad.
RE: Broken socket
Thanks, for your replies. Yes the whole bulb fell out in one piece so evidently I didn't have it screwed in very tight. Think I had better call someone to fix it.
Lois
RE: Broken socket
pharkus makes a great point that I completely zoned out on. While your install may have been legal many years ago, it's not something that's allowed by code anymore because of the fire hazard risk from say, a blanket that is in proximity to the bulb, and the bulb getting turned on accidentally.
I'm glad you're getting an electrician in. Just make sure he puts in an allowed fixture, rather than simply replacing the bulbholder.
