Lights out
Posted by eddiearms_2009 (My Page) on
Wed, Dec 28, 11 at 11:44
Second ceiling lite quit on me. Swithes are OK as are the fixtures. Old home with some knob/tube, every outlet in house OK,checked by plugging a device in. Need a clue as to where to start looking. Thanks
RE: Lights out
Most likely the problem is either at the last working fixture or at the first non-working one. If the wiring between these is indeed K&T, I would recommend that you call a (good) electrician. This is NOT a self help thing.
RE: Lights out
As a general rule, you troubleshoot by checking between the last working device and the first non-working device. If you are just blind guessing, the odds are that the circuit starts closer to the fuse box and ends farther away.
