| Hi all,
I normally hang out on the decorating forum but our electrician is racking his brains to figure this one out and I thought I'd thought it out here to see if anyone might have come across it or have any ideas. I bought a pair of Minka Aire Volterra fans and had them installed by a professional electrician. There was a slight hum/noise at first but we thought, let's let it burn in and see if that makes a difference. Well, burn it made no difference at all. It isn't a balance thing, you can hear the sound in the motor. Both fans make identical noises. Electrician came back out after talking to Minka Aire and they said the box was installed too close to a box that had a remote in it and that had caused a problem. So they sent new controllers but we had the same issue. Then Minka suggested he direct wire it to see if that got rid of the problem. Nope. Still noisy. Electrician said he would contact Minka to see if they had any further ideas but I'm getting really frustrated. I finally sprung for two of the more expensive (and beautiful) fans and I can't use them with the noise. I have an 8-year-old Hunter Douglas fan that only cost me 1/3 of the price of these fans and it's absolutely silent. I hate the thought of taking them down and taking them back but that might be my next step. Here's hoping someone has some ideas. Thank you in advance. |
Here is a link that might be useful: noisy fan
| Hum on all speeds? Any change from starting up to running? Humming often comes from poorly bonded lamination in motors or poorly secured windings. It could also be caused by a start winding (if present) not going open circuit once the fan is up to speed. If is is on two units it very well could be a design defect. |
| Maybe you are just hoping for too much, based on the exceptional performance of your previous fan. A "slight hum/noise" from an electrical device is often just part of its normal operation. |
- Posted by susanwrites (My Page) on Mon, Dec 6, 10 at 12:37
| Hi Brickeyee and thank you for your response. Just realized my typo on the post. I know it is MINKA AIRE. Sheesh. :) As soon as you click "on" no matter what speed, you hear the sound. And I don't know how to type the description of the sound but it doesn't stay the same, it cycles. Shoot, my electrician called the cycle something but I don't remember what. It's a quick cycle but you can hear it. And yes, both expensive Minka Aire fans, identical models bought from the ideal place, make the identical sound. It's beginning to look like i might need to pick a different model and go through all this crap again. Sigh. |
- Posted by susanwrites (My Page) on Mon, Dec 6, 10 at 12:46
| Wayne, maybe I do have high expectations but from a fan that is supposed to be quiet, I don't think this qualifies. And when I am sitting directly underneath it, in the case of both fans. When it's been running for a time and then I turn it off, I can feel myself relax because the noise is gone. I guess to test it I should buy another model and try that and see how it goes. |
- Posted by alan_s_thefirst (My Page) on Tue, Dec 7, 10 at 3:46
| Dumb question maybe, but are you sure it's an electrical hum and not mechanical? I've had fan/light combos that buzzed badly but it turned out the light bulbs were touching the housing or the glass fitting. Smaller bulbs and some adjustment, and the issue went away. Are you using all the approved fittings and no dimmer? Unless the dimmer is specifically right for that fitting, they'll cause issues too. |
- Posted by susanwrites (My Page) on Tue, Dec 7, 10 at 12:48
| Alan, Not dumb questions at all. Thanks for checking with me. It could very well be mechanical. It sounds like the motor to me but then I'm no expert. You can hear the sound as soon as you click it on. It's not a buzz. I doubt it's the light bulbs since both identical units make the same sound but we'll check that out. We are using everything that came in the box with the fan. When the electrician first called Minka, they mentioned the dimmer too. They even sent new controllers. No difference. We direct wired the fan, bypassing everything, and it still makes the noise. All this is leading me to believe that this model Volterra, is not up to Minka standards. I really don't think I'm being unreasonable about the sound, either but even if I am, if this can't get fixed, they will have to go. The library and my office are supposed to be the two places to go for quiet in the house. I guess the next frustrating thing is going to be how to find another fan that will go with the looks of the room and give me the quiet that I need. |
| If the fan has lights unscrew the bulbs and see if the sound disappears. Many cheap bulbs will have filament vibration when used on a dimmer. It usually appears as a 120 Hz hum as the voltage on the filaments cycles through 60 Hz. |
- Posted by susanwrites (My Page) on Tue, Dec 7, 10 at 16:29
| Thanks Brickeye. We'll give that a try this afternoon. The electrician is coming back over with one last thing to try, per Minka, before we send these back. We're going to get a long extension cord and see if we can try a different circuit in case there's something weird with the wiring in this house. The two rooms that have these fans are an addition from the previous owner. Thank you again for trying to help me figure this out. |
| I had a Hunter ceiling fan that worked well, and quietly for a couple of years and then it started making a bad 'hum' and the speeds weren't what they were before the hum. I contacted Hunter, who asked for the serial number. Within 3 days there was a brand new fan on my doorstep. They asked me to send back the defective one. I don't know what the problem was, but their customer service is excellent. |
- Posted by jaspermplants (My Page) on Mon, Dec 13, 10 at 17:53
| I had the same problem with mine and had an electrician look at it. He couldn't figure it out and told me to return it but I didn't have the receipt anymore. It's very nervewracking and I hardly use the fan now. My other Minka Aire ceiling fan has a light fixture that no longer works. I've only had it a year. The electrician couldn't figure that one out either. So, I have 2 barely functioning Minka Aire ceiling fans. I will never buy this brand again. |
- Posted by susanwrites (My Page) on Mon, Dec 13, 10 at 22:21
| Well we solved the problem. Brickeye, we went to take the bulbs out, they're those itty bitty things, but once the housing of the light fixture was off, we turned the fan on (lights still in) and there was no noise. It seemed to be that tightening the finial to attach the housing worked like a volume control. We put some padding between the finial and the glass and then just kept adjusting it until it was silent. |
- Posted by Melissa(missross@windstream.net) onMon, Mar 21, 11 at 16:01
| Hey...we have the exact same complaint. 2 Minka Volterra fans - the humming is horrible. I, too, am contemplating removing them and replacing with another brand. I won't buy another Minka Aire fan, either. |
- Posted by Cheryl(cheribear56@yahoo.com) onWed, May 4, 11 at 13:16
| Same problem..calais fan (hugger). I installed this for my sister this last weekend and the fan hums (not the lights). Fan hums at all times. I have two minkas in my house that have been there two or three years. LOVE THEM! No sound at all. We pay for that reputation! This fan is unbelievable. My sister is going to have to deal with them about this now which when I called yesterday before I left the company said it should wear it self out in 24 hrs (much be their speech)and I even asked about balancing or dimmer switch which my sister has and he said it would not be either one of those. Any suggestions from anyone? I feel bad now that I recommended Minka to her but mine are great. Again, the fan only hums (just like a cheap boxstore fan) but the lights don't. |
| "I installed this for my sister this last weekend and the fan hums (not the lights)" Did you remove the light bulbs and fixture housing to be sure? |
- Posted by susanwrites (My Page) on Tue, May 10, 11 at 16:07
| Hi folks, This is popping up in my google alerts a lot again and I'm getting emails about it. I'd just like to say, as I did further up in the posting, that we were able to fix the problem. Here's that post: Posted by susanwrites (My Page) on Well we solved the problem. Brickeye, we went to take the bulbs out, they're those itty bitty things, but once the housing of the light fixture was off, we turned the fan on (lights still in) and there was no noise. It seemed to be that tightening the finial to attach the housing worked like a volume control. We put some padding between the finial and the glass and then just kept adjusting it until it was silent. |
