| What happens when the wrong wattage lamp is installed in a HPS fixture? 150 watt lamp in a 250 watt fixture. Or vise versa? |
- Posted by ronnatalie (My Page) on Mon, Nov 21, 11 at 6:30
| Fire and brimstone coming down from the skies! Rivers and seas boiling! Forty years of darkness! Earthquakes, volcanoes... The dead rising from the grave! Human sacrifice, dogs and cats living together... mass hysteria! A ballast that is too small for the lamp may not fire it. |
- Posted by newgarageguy (My Page) on Mon, Nov 21, 11 at 20:13
| Hahahahahahaa. Thanks. |
- Posted by bus_driver (My Page) on Mon, Nov 21, 11 at 20:59
| Most of us have no definitive answer since we never tried what you suggest. No experience. My answer would be only a guess. And I never tried it since it probably would ruin the lamp or the ballast or both. And I did not want to know badly enough to spend the money for those components. If you try it, please advise the results you observed. |
- Posted by newgarageguy (My Page) on Mon, Nov 21, 11 at 21:42
| I haven't tried it nor do I plan to. I am just curious. I have found fixtures with the wrong lamps in them after they have burned out but I have no idea how long they have been that way. It seems to not hurt the ballast. After relamping, the fixture appears to work correctly. I have asked an electrical engineer this question. Go figure, he couldn't answer. |
| Many of the newest ballasts have thermal overload to protect themselves. What they do not protect against is over driving of the lamp they are connected to. Once the discharge starts (in just about any discharge bulb of any type) the impedance of the bulb becomes very low (close to zero). Use a smaller wattage bulb and the current is going to be higher than the bulb was designed for and bulb life may be short (possibly as short as a fractions of a second). Older all magnetic type ballasts are more likely to suffer damage than newer electronic ones.
- Posted by newgarageguy (My Page) on Tue, Nov 22, 11 at 21:07
| Thank you Brickeyee, Have a happy Thanksgiving. |
