| I replaced my bathroom lights and messed up the wiring downstream. The power source is a 14/2 coming directly into one of the two light fixtures. From there, I hooked up the other light and in the opposite direction used a 14/2 to connect to the 14/3 going to the switch. I wired the black to the black and red, and the white to white. The 14/3 goes into the switch box, where I tied the black to the black from the switch, the red to the black of the out-going 14/2 (power going out to 2 other rooms), and the white to the white on the switch and the white from the out-going 14/2. I obviously messed up because, though my 2 lights I installed work beautifully, the rest of the circuit is not right. Help! |
| I'd need a drawing or pictures to understand precisely what is connected to what. What's not clear is what happens to the other end of the white wire that you're using as part of the switch loop. It's quite clear that it can't be connected to both the switch and the neutral of the remaining circuit at the same time. |
- Posted by esobocinski (My Page) on Wed, Nov 2, 11 at 11:11
| I think I understand the question. Old situation: New situation: The only solution is that you need to remove that 14/2 extension of the 14/3 and replace it so that you have 14/3 all the way from the first light to the switch. Connect it so that: I don't have time to draw right now, but here's a picture from someone else. You'll have to imagine connecting the cable to the second light in the same places that the light shown is connected. |
Here is a link that might be useful: Outlet behind switch drawing
| esobocinski: you are absolutely right, on both counts. I sent a diagram to an electrically gifted friend, and his response was the same as yours. Thanks for the help! And no worries, I won't be using that circuit until I get it wired right, so no fires. Thanks! |
