Grounding
Posted by robjr (My Page) on
Fri, Nov 19, 10 at 14:09
I am installing a second light, at the end of a line, using a plastic box. What do I do with the ground wire?
Thanks, Rob
RE: Grounding
If the fixture has a grounding screw, connect it there. If not, just coil it up ar the back of the box.
RE: Grounding
Thank You!
I thought that was it, but with electricity I always try to double check.
I appreciate it!
Rob
